Cabin Flooring? - SailNet Community
 2Likes
  • 2 Post By sanssouci
post #1 of 4 Old 09-03-2013 Thread Starter
Dave_E's Avatar
Cabin Flooring?
Hi All,
After getting the Allmand 31 to the dock, it was time to really start to get to know her. The PO's installed indoor/outdoor carpet over every inch of the cabin floor... completly covering 4 bildge access ports with a ONE piece of carpet. I will agree it looks good, however I am one of those guys who looks in the holes when I get to the boat, when leave the boat and sometimes underway. One of them is where the seacock is for the engine cooling (which he just left open). Regardless of how slim the odds, I don't want to become a statistic because I left leave all my below waterline valves open.
But Allmand didn't do anything fancy for the floor... bare fiberglass. Has anyone done any kind of flooring? Suggestions for me? Thanks.
Dave
Dave_E is offline
post #2 of 4 Old 09-03-2013
Re: Cabin Flooring?
Plenty of options.. none of which should include carpet beyond a small foot mat at the base of the companionway.
A wood/planked sole could be glued to the liner, with liftouts fitted for the access points. Lonseal makes a vinyl 'equivalent' of teak and holly that has some potential, I think..
LONSEAL Flooring: LONWOOD MARINE - Lonwood Marine is Lonseal's high-performance, slip-resistant marine safety flooring. Our wood looks come in both matte and glossy styles, and have color coordinating trim.
Click on "Next" under the
If the sole is really flat then the teak and holly plywood can be had, if the liner is solid the 1/4 inch should do, if you are going to need backing anyway it pays to buy the 1/2 inch stuff.
Faster is online now
post #3 of 4 Old 09-03-2013
Re: Cabin Flooring?
Cut, bind and glue the carpet to the removable access hatches. drill a hole thru each and add a long 1/4 inch clevis type pin with a ring ding on the bottom to use as a lifting pull, it the settles into carpet while not used.
jimgo and Dave_E like this.
sanssouci is offline
post #4 of 4 Old 09-03-2013 Thread Starter
Dave_E's Avatar
Re: Cabin Flooring?
That's what I'm talkin about! I love knowledge transfer. The carpet is brand new, looks great. This will get me a couple years of use before dropping $ into a sole covering job. (Too much other stuff to spend $ on).
Dave
Dave_E is offline
replacement flooring bradway5 Gear & Maintenance 19 11-06-2012 04:38 AM
Cat 22 - teak flooring? radioguy Catalina 2 09-17-2010 06:24 PM
Suppliers for flooring adn cabin lights impromptu38 Beneteau 0 01-12-2009 08:16 PM
Replacing Teak Flooring Trescool Gear & Maintenance 1 06-23-2008 05:42 PM
Teak Flooring tjgault Gear & Maintenance 1 02-02-2004 06:33 AM
