Why does the galley sink drain... - SailNet Community
post #1 of 8 Old 09-03-2013 Thread Starter
Dave_E's Avatar
To a below the waterline seacock? The sink from the head drains to a through hull above the waterline. Why not the galley sink? Where does your grey water exit your boat?
Dave
Dave_E is offline
post #2 of 8 Old 09-03-2013
SoOkay's Avatar
Re: Why does the galley sink drain...
All of ours exit below the waterline. That's holding tanks, sinks and showers
SoOkay is offline
post #3 of 8 Old 09-03-2013
Asleep at the wheel
jimgo's Avatar
If I recall correctly, both sinks on mine drain above the waterline.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 8 Old 09-03-2013
Load Bearing Member
CarbonSink62's Avatar
Dock
My galley sink drains below the waterline.
My guess is that keeps unsightly stains off the hull.
I'm not saying it is great logic; that's just my guess.
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #5 of 8 Old 09-03-2013
Mine exit below the water line.
That said, what is the location of your sink(s)? If the sink is off centerline or there abouts, then it can back fill the boat while sailing. Centerline sinks generally don't do this as they are above waterline.
Different manufactures deal with this in their own way. Swan puts a plastic valve on the sink drain to stop water intrusion. Little Harbor had the pump in / pump out idea with a macerator on each sink, Oyster does similar. Hanse and Benateau will bulk head mount holding tanks and allow for a tank drain by opening the seacock. Others I have seen go to sumps then over board either at water line or just under deck level.
Personally I prefer the center line sink with below deck drain, as it never back fills, or need any extra pump or effort (like closing a valve while sailing)
sanssouci is offline
post #6 of 8 Old 09-03-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
my little seasprite has a below water drain.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #7 of 8 Old 09-04-2013
Stu Jackson's Avatar
In many cases the bottom of a galley sink is very close to the waterline, which means it simply can't go overboard. Overboard discharges of gray water are noisy, messy, and can, as mentioned, creates stains on the hull. Both our head and galley sinks drain underwater.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #8 of 8 Old 09-04-2013
chucklesR's Avatar
Below the water, straight down.
Even my head sinks are plumbed that way.
I've seen boats that sit at dock and spew water out onto neighbors. Bad design.
Having said that my deck funnels water to midships and spews that like a hose in a hard rain
chucklesR is offline
How does a sink drain work? jarcher Gear & Maintenance 40 04-20-2016 09:23 AM
Galley Sink Drain Dilemma Rusty123 Gear & Maintenance 5 02-06-2013 01:08 AM
sink drain ? Southron Spirit North American Yachts 10 12-10-2012 02:06 PM
Parts for sink drain overholtzer S2 1 09-07-2007 04:07 PM
galley sink HeidiMills Gear & Maintenance 4 07-26-2001 08:13 PM
