How do I get a boat off a trailer? - SailNet Community
 4Likes
post #1 of 23 Old 09-04-2013 Thread Starter
Hello!
In trying to fix up my new Lido 14 I need to take the boat off the trailer in order to get the centerboard out. (And clean up the trailer and hull) How does one go about doing such a thing? The boat is far too heavy for me to lift off, even with a couple friends. (310lbs)
Jhiggy is offline
post #2 of 23 Old 09-04-2013
Re: How do I get a boat off a trailer?
Attach trailer to car.
Now attach a line to a secure point on the boat, and tie the other end around a convenient tree.
Now accelerate as fast as you can away from the tree, and the boat will remain in place.
Just kidding. Alternative ideas :
5 friends plus you = 50 lbs each, should be no problem
Use an engine hoist to lift the boat off the trailer
Use a tree limb with a lifting block.
MarkSF is offline
post #3 of 23 Old 09-04-2013
Tartan 27' owner
CalebD's Avatar
You need to get creative.
Your friends will be your car jack, various pieces of lumber, a few cement blocks, lines, straps, a nearby tree etc.
If you can jack the hull up above the trailer so that it is supported from the sides you can then let air out of tires and remove trailer.
Otherwise get a crew of 4 or 5 to man handle it.
Everybody has one:
CalebD is offline
post #4 of 23 Old 09-04-2013
Does your garage have stout beams in the roof? Use some blocks and rope. Bonus points for using hardware off the boat.
MarkSF is offline
post #5 of 23 Old 09-04-2013 Thread Starter
All very good ideas. Is a lighter weight boat like mine ok to be placed on the ground? (On it's side? Maybe with some cardboard or something laid down?
Jhiggy is offline
post #6 of 23 Old 09-04-2013
manatee's Avatar
If it will be off-trailer for some time, one of these
http://www.qcyc.ca/sites/default/fil...ay_Cradles.pdf
plus a double-block come-along & bridle should do.
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
post #7 of 23 Old 09-04-2013
overbored's Avatar
put the trailer tongue on some blocks or the step on a ladder block the wheels, grab the transom and pull it off onto the grass. get another person and roll it over if needed. a Lido 14 hull is about 250 lbs. less sails and rig. you can also do it on a sand beach. another way it to rig the mast and pull on a shroud and walk up the mast until it is laying on it's side. very strong boat and it can lay on the mast tip all day. makes it easy to work on the centerboard with it on it's side.
http://www.lido14.org/lidopedia/Doub...board%20v3.pdf
"GOLD RUSH" PRINDLE 16
overbored is offline
post #8 of 23 Old 09-04-2013
Bring On The Wind
CatMan22's Avatar
First you need the following:
Floor Jack
(2) Jack Stands
(2) 4 x 4 x 8
(2) 2 x 4 x 8
4" Foam Rubber
First place the floor jack under the rear of the trailer and lift it a foot or so then place the jack stands under both sides of the trailer to steady it.
Next cut the 2 x 4's to approximately 3 foot lengths then cut the remaining pieces so you can form a v when you place the three foot cuts on the 4 x 4's. Screw them together and set them on the blocks with enough room to place the foam rubber between the boat and wood. Now raise the trailer just enough to remove the jack stands and lower the trailer, the boat should rest on the stand you made and after repeating the process on the front of the boat you should be able to pull the trailer out from under the stands. If the 8 footers wont clear your trailer wheels substitute 12 footers instead.
S/V CatManDeux
Catalina 22
"hark, now hear the sailors cry,
smell the sea, and feel the sky
let your soul & spirit fly, into the mystic..."
Van Morrison
CatMan22 is offline
post #9 of 23 Old 09-04-2013 Thread Starter
Floor Jack
(2) Jack Stands
(2) 4 x 4 x 8
(2) 2 x 4 x 8
4" Foam Rubber
I'm having a hard time visualizing this. Do you have a picture?
Jhiggy is offline
post #10 of 23 Old 09-04-2013
overbored's Avatar
Floor Jack
(2) Jack Stands
(2) 4 x 4 x 8
(2) 2 x 4 x 8
4" Foam Rubber
All that for a lido 14 I guess I have been doing it the easy way all these years. next time I want to do way more work getting ours off the trailer I will try this. you have not sailed a lido 14 have you. I can get ours off by my self onto the grass
Need help getting boat off trailer g0twind General Discussion (sailing related) 16 09-06-2013 03:02 PM
changing tire on trailer with boat on trailer johnnyandjebus General Discussion (sailing related) 14 07-01-2012 05:09 PM
boat trailer redlady Gear & Maintenance 0 05-20-2003 09:09 AM
Need trailer for 24 ft boat 1Rsalsman23 Boat Review and Purchase Forum 1 02-13-2003 06:05 AM
Looking for trailer for 23'' boat decatur General Discussion (sailing related) 4 01-10-2002 06:10 AM
