Backing plates, what do you use? - Page 2 - SailNet Community
 9Likes
post #11 of 26 Old 09-05-2013
Re: Backing plates, what do you use?
The backing plate is only one component – you must also think where you are positioning the hardware – some places have balsa core which cannot take the compression when you tighten the bolts. If this is the case you’ll need stainless spacers to put the bolts inside – they will take the load without damaging the deck. And don't forget the butyl....
SVTatia is offline
post #12 of 26 Old 03-19-2014
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
remove the core around the bolts and fill with thickened epoxy to prevent compression use a countersink to allow butyl to form O ring around the bolts
my $ 0.02
Bill-Rangatira is offline
post #13 of 26 Old 03-19-2014
I don't discuss my member
zz4gta's Avatar
G10 for material.
sailordave likes this.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #14 of 26 Old 03-19-2014
Starboard, and cutting boards are not sutable for backing plates. The plastic they use is junk, and will deform under light compression loads applied for any length of time. I don't know who first thought of them, but it is a terrible idea.
The prefered is either a stainless plate, which should be available at almost any metal shop for a couple of bucks, or G10. G10 is a fiberglass board made under high pressure, and is extremely strong. It does tend to ruin blades, but bi-metal or carbide blades work ok. Just go slow since the board won't disperse heat like cutting into metal will.
Greg
Stumble is online now
post #15 of 26 Old 03-19-2014
Not Finished Yet
RainDog's Avatar
You can order them custom made to your specs here: https://www.stainlesssupply.com/orde...eel-sheets.php
RainDog is offline
post #16 of 26 Old 03-19-2014
mitiempo's Avatar
Originally Posted by Frogwatch View Post
I'd use 3/16" G10 Garolite from McMaster-Carr. It is stronger in compression than Ssteel and will not cause any corrosion.
I don't believe G10 is stronger in compression than stainless steel.
Corrosion? The nuts and bolts will be stainless as well so no problem there.
Brian
mitiempo is offline
post #17 of 26 Old 03-19-2014
Actually G10 is stronger in compression.
G10 is 365 GPa, versus 310GPa for 316 stainless.
Greg
post #18 of 26 Old 03-20-2014
mitiempo's Avatar
I didn't know that, interesting.
Brian
mitiempo is offline
post #19 of 26 Old 03-20-2014
Send a message via Skype™ to LaurenceU
I think you mean MPa (MegaPascals).
Laurence
LaurenceU is offline
post #20 of 26 Old 03-20-2014
Lol, WOOPS. Good catch Laurence.
Greg
Backing plates micheck General Discussion (sailing related) 7 11-14-2010 01:27 AM
Oak for backing plates? Mandofish Gear & Maintenance 34 04-04-2009 09:06 PM
Backing Plates painkiller Gear & Maintenance 29 02-19-2009 02:17 PM
Backing plates SVCetacea Gear & Maintenance 53 12-01-2007 08:01 PM
Backing Plates TXS-ALAMO Gear & Maintenance 6 10-31-2007 08:03 PM
