Rust colored organisms - SailNet Community
post #1 of 3 Old 08-29-2004 Thread Starter
We have many aproximately 1/8" "stains" in our cockpit. We think they''re from using harbor water to flush the cockpit. We''re in Great Kills Harbor, off Raritan Bay NY_NJ. We''ve tried boat soap, straight bleach, bronze wool, comet, limeout. They fade but they''re imbedded. Anyone have this experience and a solution for it. Our boat is fiberglass and about 30 yrs old. It''s no where but the cockpit.
bacc is offline
post #2 of 3 Old 09-01-2004
Are you certain that at some time you or a yard mechanic didn''t use your cockpit as a saw horse to cut off or grind a piece of metal? Small particles will stick pretty well and can be tough to remove.
soapstone is offline
post #3 of 3 Old 09-04-2004
msl
Years ago I used steel wool to clean up a corroded fitting. The rust stains showed up soon after. Yikes!!! What a mess.
msl is offline
Sail Rust Stain Removal davidusvi Gear & Maintenance 8 08-14-2012 12:58 AM
Tiny rust spots from nearby grinders VIEXILE Gear & Maintenance 7 04-09-2004 06:22 AM
rust in the bilge from a bolt... sara_lugli Gear & Maintenance 3 02-04-2004 04:23 AM
rust in non metallic sinks c2cSailor Gear & Maintenance 3 08-21-2003 05:04 PM
rust on keel gregreinhard Gear & Maintenance 1 01-20-2003 03:08 AM
