Water in the bilge - Page 2 - SailNet Community
 1Likes
post #11 of 18 Old 09-08-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Water in the bilge
My SeaSprite leaks and it is on a trailer. I need to redo the hatches and rebed the ports
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #12 of 18 Old 09-08-2013
Over Hill Sailing Club
smurphny's Avatar
I can always tell when the packing nut needs tightening by hearing the bilge pump come on. The shaft log is so buried in my boat that seeing it is not an option without mirrors and great feats of Yoga. I have to feel to get wrenches on it. My shaft log wrenches have line attached so dropping them down into never-never land is not possible.
smurphny is offline
post #13 of 18 Old 09-08-2013
The most female moderator
Donna_F's Avatar
Dock
My last boat was on a trailer during the off season. By launch time I had removed water by the bucketful. During the season I kept it in a slip. Barely a drip, even after the heaviest rainfall. I suspect that the boat, designed to be in water, flexes differently when stuck on a trailer, whence more points of ingress that didn't occur when it was stored in the water. Since I was more concerned about what happened when it was in the water where it was supposed to be, I left it alone.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #14 of 18 Old 09-08-2013
In one of the first years with my boat I did not get her winter cover on for about a month after pulling in the fall. I noticed that a few ports were leaking, and they never leaked in heavy storms or from green water over the bow. Opened all the ports and closed them again. It was the flex of the boat when the rigging came down that caused the leak. Sure glad I did not FIX all those seals.
tomandchris is offline
post #15 of 18 Old 09-09-2013
Splashed
JomsViking's Avatar
I seem to be in the minority re. this.
But as I've managed to make 3 of my own and several other peoples boats bone dry I'm of the firm opinion that this should be done - Just the other day the neighbor boat noticed a Little Water in the bilge (which usually is bone dry) and we traced it to the raw Water pump. The amount was so tiny he wouldn't have noticed in a "wet bilge".
In heavy weather a heck of a lot of Water can get in through locker lids etc which may only cause a very tiny amount the rest of the time, but you'll be happy that you took the time to stop it when the sh1te hits the fan..
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
post #16 of 18 Old 09-09-2013
We have a low bilge, within our bilge, that will collect and hold about a half gallon of water, if it filled up. The float switch and main bilge pickup are in it. The backup is above it.
We have two fridges that drain to this lower bilge, along with the condensation from two air conditioning units. The pressure blowout for the hot water heater would also go there, if it let go.
As a result, our bilge pump runs a couple of times per day. It was creepy at first. After seeing a bone dry bilge surrounding it, I just got used to it and consider it an audible test that the bilge pump actually works.
My bigger problem is that water coming down my mast collects in a bilge compartment that just won't find its way to this lower bilge to be pumped out. I shop vac it out, but its frustrating.
Jeanneau 54DS
Minnewaska is offline
post #17 of 18 Old 09-09-2013
s/v Tiger Lily
dvuyxx's Avatar
Mine always has a small amount of water. You need to be in your cabin during a rainstorm and try to see if you see water trickling in the sides of your bilge. That might lend some clues. I have a leaky hatch among a couple of other fittings that need to be addressed.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #18 of 18 Old 09-09-2013
Have you considered that it might just be the back wash water in the line that doesn't make it out based on the length of travel and the rise of the outlet.
justified is offline
What to do with bilge water? dvuyxx Gear & Maintenance 34 07-17-2011 10:38 AM
Bilge water - what's too much Tanley General Discussion (sailing related) 9 06-02-2010 11:36 PM
water in the bilge sailhog Gear & Maintenance 25 03-17-2007 09:40 AM
Where does bilge water come from? chris1514 Gear & Maintenance 8 07-27-2003 07:51 AM
Water in the Bilge Dan Dickison Gear and Maintenance Articles 0 03-12-2001 07:00 PM
