Water in the bilge - SailNet Community
 1Likes
post #1 of 18 Old 09-08-2013 Thread Starter
Dave_E's Avatar
Water in the bilge
Hi All,
Just wondering how many 30+ year old boats seem to always have a bit of water in the bilge? The Allmand seems to always have a couple cups worth in the bilge. I've fixed a leaky raw water pump, have a couple drips coming out of the shaft seal, but can't really see anything obvious. We had a 2" rainstorm couple days ago... that shouldn't have mattered. My refrigerator drain does go to the bilge, as does the bathroom floor drain (poor desion in my mind). Never enough to kick on the low automatic pump.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 18 Old 09-08-2013
Splashed
JomsViking's Avatar
Re: Water in the bilge
IMHO the bilges should only accumulate dust, not Water. But can't really tell what/why you get some. Hatches, Windows, etc are likely culprits if fresh, and you already solved some of the saltwater ones.
Watch great footage about the story of one manís slow odyssey around the UK:
JomsViking is offline
post #3 of 18 Old 09-08-2013
Water gets in to my bilge via the keel stepped mast, rarely enough to engage the automatic pump though.
tempest is online now
post #4 of 18 Old 09-08-2013
Doesn't sail enough
zedboy's Avatar
My 60+ year year old boat always had water in the bilge after rainstorms. It was cause everything leaked.
zedboy is offline
post #5 of 18 Old 09-08-2013
asdf38's Avatar
That doesn't sound like a problem to me at all.
There are a lot of sources of water on a boat including ones that have nothing to do with leaks like condensation from the hull or fridge. If all you have is a couple of cups of water and you know your shaft seal drips that's basically nothing.
That said, don't underestimate rain leaks. All the water that gets into my bilge, and it's more than you, is from rain. While there are just a few holes in the hull of your boat there are probably more than 100 on the top of your boat. Every one one is a potential leak. And things like hatch boards, hatches, and portlights often don't seal as well as they should.
jimgo likes this.
asdf38 is offline
post #6 of 18 Old 09-08-2013
Yeah two of my windows need to be resealed and leak a little bit every time it rains hard or I wash the boat down. I'm waiting for it to get high enough to use the bildge pump.
HaleyF is offline
post #7 of 18 Old 09-08-2013
Asleep at the wheel
jimgo's Avatar
I have water in my bilge, too. As others have said, it can come from a variety of places, including rain intrusion and thru-hulls.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 18 Old 09-08-2013 Thread Starter
Dave_E's Avatar
Thanks much for the replies. I've been around boats most of my life, seen it, heard it, talked about it... but when the big boat is yours for the first time... puts a different perspective on it. Sometimes we just need reassurance from our mates.
Dave
GOD, Family, career
Dave_E is offline
post #9 of 18 Old 09-08-2013
snake charmer, cat herder
zeehag's Avatar
when you have an inboard engne and packing gland and rain and such you will have wet bilges.
most boats have a little water in their bilges--even my dry as a bone ericson has water in bilge.
my formosa, a truly active cruising boat has plenty water in bilges--i consider it ballast!!--i have to pump every week---which is better than every day.
only dry boat is one on hard in desert
formosa 41, cruising tropics
zeehag is offline
post #10 of 18 Old 09-08-2013
Asleep at the wheel
jimgo's Avatar
As you sit at the dock, listen carefully. You will hear the automatic bilge pump of many of the boats going on and off. That's what told me that mine was more the norm than the exception. That's not to say I don't want to figure out where most of it is coming from and stop it, but I figured it was a sign that I wasn't in serious trouble.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
What to do with bilge water? dvuyxx Gear & Maintenance 34 07-17-2011 10:38 AM
Bilge water - what's too much Tanley General Discussion (sailing related) 9 06-02-2010 11:36 PM
water in the bilge sailhog Gear & Maintenance 25 03-17-2007 09:40 AM
Where does bilge water come from? chris1514 Gear & Maintenance 8 07-27-2003 07:51 AM
Water in the Bilge Dan Dickison Gear and Maintenance Articles 0 03-12-2001 07:00 PM
