Lubricating Sail Slugs? - Page 2 - SailNet Community
 11Likes
post #11 of 16 Old 09-10-2013
Re: Lubricating Sail Slugs?
Originally Posted by capttb View Post
I'm honored to announce this year's winner of the Red Green Award (sailboat division) for creating the most innovative useful device from a spare parts bucket and duct tape is:
Eherlihy
Yes, but does it work on the boom too?
Seaduction is offline
post #12 of 16 Old 09-10-2013
Learning the HARD way...
eherlihy's Avatar
Thanks!
eherlihy is offline
post #13 of 16 Old 09-11-2013
s/v Tiger Lily
dvuyxx's Avatar
Eherlihy that is the most awesome Mcgyver fabrication I've seen in awhile.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #14 of 16 Old 09-13-2013
Lemon Pledge furniture wax works great. I spray it in the slot as i raise the main. That is "wax dissolved in a solvent" but much less expensive than a bike specialty product or a silicon lubricant like sailcoat.
Plus it makes your mast smell lemony fresh!
jhaley66 is offline
post #15 of 16 Old 09-13-2013
gts1544
I second the suggestion of using "ordinary garden variety" silicone lubricating spray for lubrication. When she gets sticky, I simply spray the track at the base prior to each slug being raised. Works like a champ and cheap! I have never attempted to clean the entire track. An interesting thought!
gts1544 is offline
post #16 of 16 Old 09-14-2013
blutoyz's Avatar
Originally Posted by eherlihy View Post
consolidated from an old post of mine;
I had some old track slides. I took 2 of them, and connected them with a 1" bar of aluminum. I then fit a piece of the really coarse (red) scotch-brite pad between them. Then, I taped an old hinge to the top of a can of McLube Sailcoat, so that when I pushed the hinge, it activates the sprayer. Finally, I taped the can of McLube to the 1" aluminum bar.
From the side, you can see the inventive use of Duct tape.
I attach a halyard to the top track slide, and a line to the bottom and feed the whole contraption into the track. I also have another line attached to the hinge, so that I can use the spray can remotely.
I connect a halyard and downhaul onto that loop of string, and a piece of fishing line onto the hinge.
I pull the thing up and down the track a few times, so that the scotch brite can do it's thing, then, starting at the top, I pull the whole mess down the track while activating the sprayer.
From the top;
The Scotchbrite - trimmed to fit the width of the track, goes in between the two sail track slides. The pad that I use is actually from a floor sander.
Works like a champ!
You are a mad scientist...
blutoyz is offline
New Main, What type of Sail Slugs? 75c30 Gear & Maintenance 7 05-30-2011 07:15 AM
Lubricating sail slide CapnRon47 Gear & Maintenance 14 09-14-2010 09:44 PM
Sail Slugs for a Jib? Quickstep192 Gear & Maintenance 3 09-22-2008 04:59 PM
Bolt rope or Sail Slugs Finallybuyingaboat Gear & Maintenance 29 06-19-2008 03:37 PM
Sail Slugs dave6330 Gear & Maintenance 26 09-13-2007 04:49 AM
