Stupid oil / grease question - SailNet Community
post #1 of 13 Old 09-10-2013 Thread Starter
Jiminri's Avatar
My manual windlass has an oil reservoir and a plate that says to fill with "Oil Grade SAE 140 Or Nearest" I'm not familiar with what this is.
Where would I find this...an automotive store? No luck at WM.
Nonsuch 30 Ultra #343 1986
West River, MD
Jiminri is offline
post #2 of 13 Old 09-10-2013
Tartan 27' owner
CalebD's Avatar
Dock
Re: Stupid oil / grease question
Oil is not stupid and neither are questions.
5W oil is very thin
30W oil flows
90W oil might go in a manual transmission gear case, it is pretty thick
140W oil might very well be a good grease
Everybody has one:
CalebD is offline
post #3 of 13 Old 09-10-2013
To add to Caleb's good post..
http://www.kuttenkeuler.de/kkweb/Dow...jectId=1000462
Looks like a heavy gear oil.. IIRC most differential case oil is SAE 90 - pretty heavy compared to motor oil already... so this is going to be nearly grease.
Faster is online now
post #4 of 13 Old 09-10-2013
Google "heavy duty gear oil" and you'll find sources online for purchase.
Seaduction is offline
post #5 of 13 Old 09-10-2013 Thread Starter
Jiminri's Avatar
I have only found a multi-grade so far:
Lucas Oil 10042 SAE 85W-140 Heavy Duty Gear Oil
Think that will work?
Also, I found a manual on-line for the windlass (a Simpson-Lawrence Hyspeed) and THAT says
Automotive Gearbox Oil SAE Grade EP80
Which, seems to not agree with the tag on the windlass.
What would you use?
West River, MD
Jiminri is offline
post #6 of 13 Old 09-10-2013
Tartan 27' owner
CalebD's Avatar
Dock
Get a quart of SAE 90W gear box oil and try it out. It is close to the consistency of honey or molasses but will still flow slowly. Won't cost that much either at Napa or similar.
I'd believe the manual more than a random tag attached to the windlass.
Everybody has one:
CalebD is offline
post #7 of 13 Old 09-10-2013
I would go with the multi grade but SAE 90 W will work you aren't dealing with high speeds or excessive loading...
Bob142
Desolation Sound
Maple Leaf 48
Any storm in a port...
Bob142 is offline
post #8 of 13 Old 09-11-2013
What would you use?
Single grade oils have generally been superceded by multigrades, which have viscosity modifiers to reduce their tendency to get thinner as they heat up. I don't think you'll get any wear problems with the multigrade oil, but I do wonder if you'll have trouble with it pouring out of the winch when you're on well heeled on a tack, as the multigrade is thinner when cold.
MarkSF is offline
post #9 of 13 Old 09-11-2013
You can order from Advance Auto Parts: Buy Lucas Oil Products SAE 80W-90 Gear Oil 10043 at Advance Auto Parts
The EP designation means "extreme pressure"
post #10 of 13 Old 09-11-2013
snake charmer, cat herder
zeehag's Avatar
gear oil is 80-180 wt--- 140 is a mid weight gear oil and will be found at napa or auto zone, mebbe. wallys wont have it----nor will costco.
lower end unit lube could well be what you need, if it is proper weight.
formosa 41, cruising tropics
zeehag is offline
A really stupid question PaulinVictoria Learning to Sail 11 03-29-2010 12:47 PM
Stupid Question krozet Boat Review and Purchase Forum 15 10-11-2009 11:30 AM
Stupid question... or not? samurai6 Learning to Sail 6 09-05-2009 07:28 PM
Stupid radio, stupid question. (stupid owner?) jjns Gear & Maintenance 8 06-22-2009 06:08 AM
Stupid Question wcconway Catalina 4 08-20-2008 11:21 PM
