Question regarding 2qm15 mixing elbow part numbers - SailNet Community
post #1 of 3 Old 09-10-2013 Thread Starter
CanadianNorth's Avatar
I am looking for a U shaped mixing elbow fora 2qm15. A company (that is willing to ship to canada!!) has the 124070-13521 and they are claiming that it is the same as 124070-13520 which is listed as my original part.....
does anyone know if this is correct?
thanks
___________________
High Hopes
1979 Glastron Spirit 28, Hull #28.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off your bowlines. Sail away from safe harbor. Catch the trade winds in your sails. Explore, Dream, Discover.
Mark Twain
CanadianNorth is offline
post #2 of 3 Old 09-11-2013 Thread Starter
Re: Question regarding 2qm15 mixing elbow part numbers
I should clarify that's a yanmar 2qm15
___________________
High Hopes
Mark Twain
post #3 of 3 Old 09-12-2013
JimsCAL's Avatar
Yanmar seems to have multiple part numbers for their U-type exhaust elbows. I replaced mine this spring on my 3GM30F. Toughest part was getting everything apart. Local Yanmar dealer just needed the engine model to give me the replacement. Note there is a fitting that looks like a coupling that has RH threads on one end and LH threads on the other. You'll need that if you don't have it or damage the old one removing it. Also need a gasket for the manifold that attaches to the engine.
I suspect this is the part you have been quoted. Looks like my elbow.
104214-13521 Yanmar U-Type Exhaust Elbow
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
CanadianNorth (10-26-2013)
Another Yanmar Exhaust Mixing-Elbow Question saildork Diesel 6 01-13-2013 01:28 PM
Fouling of Mixing Elbow trantor12020 Diesel 12 12-09-2010 08:52 AM
Yanmar mixing elbow rchad Diesel 3 05-02-2010 05:56 PM
Mixing elbow trantor12020 Gear & Maintenance 10 09-27-2008 07:29 AM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
