Lewmar Hatch Panel - Adhesive - SailNet Community
post #1 of 7 Old 08-31-2004 Thread Starter
I have a small Lewmar hatch that, to my great surprise, has its locking handle GLUED to the acrylic panel. The handle (plastic) came off and it needs to be reglued. The glue that''s on there now appears to be a dark brown or black color.
Anybody know what kind of glue/adhesive I should use?
George
parvenu is offline
post #2 of 7 Old 09-01-2004
Methacrylate?
GordMay is offline
post #3 of 7 Old 09-01-2004 Thread Starter
Hi GordonMay,
I''m assuming the material you''re referencing is the hatch panel. I do not know what that material is made of.
But if I''m understanding you correctly and it is that material,do you have a recommendation for the adhesive?
George
parvenu is offline
post #4 of 7 Old 09-01-2004
George
You are right, about hatch cover being built of that stuff. And; Gord is right (he usually is). The first site listed on Goggle gives it as -- methyl methacrylate. This site does not give us the adhesive to use, but it is interesting reading. --------------- http://www.psrc.usm.edu/macrog/pmma.htm
I am still looking.
Walt Ward
waltward is offline
post #5 of 7 Old 10-22-2009
Has anyone come up with the proper glue for this? We've tried about 5 different types of adhesive and can't get this handle to stay attached to the hatch. Rather than order a whole new hatch, I'm considering drilling a hole int e hatch an screwing or bolting this thing in.
TWMatt is offline
post #6 of 7 Old 10-23-2009
nickmerc's Avatar
Did you try contacting Lewmar?
________
Cannabis Seeds
nickmerc is offline
post #7 of 7 Old 01-06-2010
Lewmar glue on hatch handle
In case this is still an open question, I just went through this. Have Lewmar low profile size 10 hatch. Latch broke at the piece glued on the hatch lens. Latches are glued on at the factory and was not able to find anyone that can re-glue or help. There are (were) 2 options:
1. purchase a new new lens. The lens has a gasket and the frame is split (2 piece). Separate the 2 pieces of the frame, slide out the old lens and gasket, slide in the new one and reassemble the frame.
2. purchase a new hatch and swap out the tops by pulling the hinge pins. Not cheap but goes fairly easily.
I went with number 2 since it is pretty cold here and i wanted it to go quickly and didn't want to fool with the gasket in the cold.
Right after I finished I learned from Lewmar that they have now changed the design to bolt through latches and going forward the latches will be replaceable without replacing the lens. Obviously some suppliers will be trying to move the older glue-on models so try to get replacement lenses or hatches with the new feature if you think the latches will break with any frequency. I have only had one out of 8 break so far and I have no idea why it broke.
Hope this helps.
Kirk
s/v Ainulindale
nodee is offline
Fitting a hatch in a cambered deck Crip Gear & Maintenance 1 08-28-2003 02:46 AM
solar panel maestro Gear & Maintenance 3 11-20-2002 12:02 PM
Reparing Forward Hatch on CAL 2-27 janaclek9 Racing 3 03-27-2002 01:34 PM
Hard to Open Sliding Hatch sjacovino Gear & Maintenance 6 02-13-2002 08:29 PM
Floor Hatch Repair rickandtyra Gear & Maintenance 0 07-29-2001 05:49 AM
