Went up the mast :-( - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 09-12-2013
Tanley's Avatar
Re: Went up the mast :-(
Dave,
Did you get a picture of the masthead that you can share? We had a rigger go up our mast after we had some issues with one of the sheaves. When he got down, he reported the masthead could not be worked on w/o dropping the mast. I did so that off season only to find out the masthead was designed to be completely accessible while stepped. The rigger missed 2 - 9/16" nuts that held a cap on top of the mast step. Once these are backed off, the sheaves are readily serviceable.
No hard feelings as I didn't know either and wanted to inspect the rigging that off season anyway. I'm sure there are a lot of different designs out there, and nothing seems obvious when you're 50' in the air on a 1/2" line.
Point being, put some photo's up if you have them and maybe someone here has seen your setup before.
Good luck
Tanley is offline
post #12 of 13 Old 09-12-2013 Thread Starter
Dave_E's Avatar
Originally Posted by Tanley View Post
Dave,
Good luck
Point well taken, THANK YOU! I'm going up tomorrow night to see if the lube I laid down did any good. I'll take the camera (wanted pictures of the view anyway) and look at things again closely.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #13 of 13 Old 09-12-2013
Tanley's Avatar
Found this after the fact, it's the breakout of the masthead used on our boat. If you dig around the site you may find yours. Look under the "Spars" section then dig down by manufacturer.
Don't forget - in the event you can get into your masthead, you can't work on the sheave you're using for the ascender...
NG1 Masthead Assembly
jimgo likes this.
Tanley is offline
Video from the top of the mast: repairing mast light wires jameswilson29 Gear & Maintenance 7 06-03-2013 03:45 PM
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
