Help with Old Engine - SailNet Community
post #1 of 5 Old 09-01-2004 Thread Starter
I purchased a 1966 Pearson Wanderer and I need help with the engine. On the heat exchange it says Lathrop. Does that mean it is a Lathrop engine? It does not appear to be an Atomic 4. I am trying to have the head redone and I need parts (no where to find them). I know very little about engines but there are springs in the head that need to be replaced.
Any help will be a help.
Thanks
Whompper is offline
post #2 of 5 Old 09-01-2004
is it a gas or diesel engine??? Is it a straight shaft with stuffing box or an attached lower unit protruding from the hull?? Is it a 1,2 or 4 cylinder engine?? This might help....
maestro is offline
post #3 of 5 Old 09-01-2004
Whompper
This site would be a good place for you to start, he has links to other sites as well. -
-- http://www.pearsoninfo.net/index.cfm
Then you might want to jump onto the Pearson Discussion List here on Sailnet. Sometimes the best information comes from owners of the same boat.
Walt Ward
waltward is offline
post #4 of 5 Old 09-03-2004 Thread Starter
It is a 4 cylinder, gas engine.
Whompper is offline
post #5 of 5 Old 09-07-2004
You might also want to check out oldmarineengine.com.
williamjchampion is offline
slight oil slick in diesel engine exhaust mcagney Gear & Maintenance 7 04-04-2013 02:15 AM
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 06:14 PM
engine facing aft with saildrive installation levenezia Gear & Maintenance 3 01-16-2005 11:35 AM
Engine Removal drynoc Gear & Maintenance 4 01-04-2005 07:21 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
