Gas question.... - SailNet Community
post #1 of 7 Old 09-15-2013 Thread Starter
Gas question....
Hey folks
With my 2008 Beneteau Oceanis 31 (and 34 and 37 I think are the same) the gas tanks for the galley stove are in the cockpit burred beside the life raft area - This is a bit of a pain to get to every time you want to turn on and off the stove for a cup of tea.
My question for the group is this, with the gas shut off directly below the stove, is it required/common practice to shut off the gas at the source (tanks in the cockpit) every time? The previous owner kept the gas on at the tanks and used the cabin shut off as regular practice ....I like the ease of use with his routine , but want to ensure its safe too.
Many thx!
ChuckBuck is offline
post #2 of 7 Old 09-15-2013
mitiempo's Avatar
Re: Gas question....
If the cabin shut off is a switch that controls the tank locker installed solenoid that is what many do. If you are leaving the boat for a while the tank can of course be manually closed as well.
Brian
mitiempo is offline
post #3 of 7 Old 09-15-2013
jimrafford's Avatar
There should be a solenoid at the tank. If there isn't one, install one before we read your obit!
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #4 of 7 Old 09-16-2013
Best practice these days would be a solenoid at the tank, operated by a switch near to the stove - but accessible in case of a stove-top fire. The switch module should also have a leak detector attached, and can switch off the propane at the tank automatically in case of a leak.
With this setup I feel OK about the manual valve open on the bottle - although I'll still turn it off for the day's sailing, or if I'm leaving the boat.
MarkSF is offline
post #5 of 7 Old 09-16-2013
Yorksailor's Avatar
Mark has it right and the video is why it is necessary.
People are maimed or die in these accident.
Yorksailor is offline
post #6 of 7 Old 09-16-2013
Dirt Free
boatpoker's Avatar
Safe Boat Propane Installation
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #7 of 7 Old 09-16-2013
Old as Dirt!
svHyLyte's Avatar
Originally Posted by ChuckBuck View Post
Hey folks
Many thx!
As others have stated, above, one should have a Solenoid activated gas valve coupled with propane sniffers, and frankly, on that Bene, I'd be surprised if you do not, but if not, it would be wise to look into (see for example the Xintex S-2A Propane Monitor in the SailNet Store, above left). Beyond that however, it is also wise to keep one's propane shut off at the tank when not needed. We do so but also keep a couple of good quality Thermos bottles in the galley that we fill before shutting down the propane system after cooking a meal. One filled with just hot water, for my much better half to make tea or hot cocoa or instant soup with and one filled with coffee. We actually have a number of such bottles and, on passages, usually also have one filled with hot thick soup which can give one a good energy boost and warm-up on a long dark chill night passage. A good quality thermos bottle will keep its contents very hot for quite a long while and is more convenient than trying to heat a tea kettle of water underway, eh?
FWIW...
svHyLyte is offline
Gun question beej67 General Discussion (sailing related) 129 03-09-2012 07:22 PM
Tax Question... palomar General Discussion (sailing related) 15 02-03-2012 01:16 PM
Simple question, but still a question:keel repair eckcn17 Gear & Maintenance 9 03-16-2011 11:01 AM
The $64,000.00 question Maverick1958 Cruising & Liveaboard Forum 12 02-01-2010 11:47 AM
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
