Re-caulking companion way hatch cover - SailNet Community
post #1 of 3 Old 09-16-2013 Thread Starter
flandria's Avatar
Dock
The seams of the cover over the companion way hatch on my Catalina 36 MkII "have given up" and (rain) water now makes its way from there to the cockpit. I have to remove and replace the caulking. Since this is a cover that may need to be removed, what sealant should I use? And, other than patiently scraping away what is there (original factory applied sealant) and cleaning with paint thinner, or similar, is there an other, efficient way to remove the old sealant?
Many thanks for advice!
flandria is offline
post #2 of 3 Old 09-16-2013
Asleep at the wheel
jimgo's Avatar
Re: Re-caulking companion way hatch cover
I used butyl tape and it seems to be working well. Getting the old sealant up is a PITA, because the PO on my boat used silicone. I wound up having to sand it out after I had scraped off the big stuff.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #3 of 3 Old 09-17-2013
I found Acetone and 3M Adhesive remover works well, along with patience and scraping. Soak the area and let stand after spraying with the 3M remover. Recommend a mask to help with fumes and gloves. The black disposable gloves work better than blue nitrile or vinyl gloves. Butyl tape is good, I also use and like sikaflex 291 and 3M 4200.
ambianceack is offline
Companion way cover PAULCR1 Gear & Maintenance 2 12-18-2012 10:46 AM
Hatch cover CS36T JohnMaschek CS Yachts 3 12-15-2009 06:57 PM
Pearson 27' Companion Way Hatch ano1 Pearson 0 10-31-2009 04:40 PM
Hatch cover MMatus Seamanship & Navigation 5 07-03-2008 05:13 PM
Hatch cover MMatus General Discussion (sailing related) 2 03-07-2004 08:48 PM
