Speedo Help Please - SailNet Community
 10Likes
post #1 of 11 Old 09-16-2013 Thread Starter
Dave_E's Avatar
Speedo Help Please
Hi All,
Took Traveler out for our first sail Saturday, everything went great except today... no speed-o-meter. This is actually the way I expect the 34 year old girl to act (things need tending to). Anyway it's an old Kenyon paddle transducer type in the bow. I have one of those type that has a big collar on it that unscrews and the unit pulls out toward you in the boat. Now I'm guessing I can plug the hole while I try to see if the paddle got gummed up or something. Does anyone do this? Sounds scary to the Mrs.
We used the GPS (don't know which way the tides were running), and it showed 4.5k out of 8k of wind. I didn't think that was too bad.
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
The Following User Says Thank You to Dave_E For This Useful Post:
whughes (09-16-2013)
post #2 of 11 Old 09-16-2013
tommays's Avatar
Re: Speedo Help Please
NORMALY there is a blank plug and you do a quick swap BUT it will squirt pretty good
I would also be a bit apprehensive about and unknown unit that had been in the hole for prolonged period if time
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 11 Old 09-16-2013
johnnyquest37's Avatar
My knotmeter comes with a plug that screws in for when I take the paddlewheel knotmeter out. There is also a rubber flap in the hole that slows down the water entering the boat while the knotmeter (or the plug) is out of the hole. First thing to do is take the knotmeter out of the hole and clean off any marine growth. Give the paddlewheel a spin and see if it registers at the display. If it does, then you know the wiring is good. If the knotmeter continues to register zero after you put it back in the hole, then you likely have some marine growth impeding the flow over the paddlewheels.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #4 of 11 Old 09-16-2013
chucklesR's Avatar
My advice on speedo's is that men over 50 should generally not wear them.
olson34, T37Chef, zeehag and 3 others like this.
chucklesR is offline
post #5 of 11 Old 09-16-2013
or men under 50, for that matter.
zeehag, jameswilson29 and rugosa like this.
[/B]S/V Wind Orchid
Annapolis, MD
post #6 of 11 Old 09-16-2013
The most female moderator
Donna_F's Avatar
Dock
The amount of water that enters the boat before you get the plug in is a bit alarming at first, but not enough to sink the boat.
We clean ours when on the hard but when it gunks up, we really don't need to know our speed that badly that we bother with it when the boat is in the water.
Donna
Catalina 30 TRBS
Rock Hall, MD
Donna_F is offline
post #7 of 11 Old 09-16-2013
Asleep at the wheel
jimgo's Avatar
Dave, if you have a GPS, given that you're going to likely be hauling out in a few weeks, why not wait 'til then rather than have to worry about plugs, leaks, etc.?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #8 of 11 Old 09-16-2013
T37Chef's Avatar
I am not helping another man with their speedo! No way no how
oh wait
zeehag likes this.
T37Chef is offline
post #9 of 11 Old 09-16-2013 Thread Starter
Dave_E's Avatar
OK... I get the "speedo" thing.
I've decided to leave the boat in the water until May, un-step the mast in January. I'll live with it. The Kenyon is an antique anyway. That's 2 out of the 3 basic instruments that don't work anymore. Think I'll put a new set of Signet Marine instruments in. They still make big round ones that will fit right where these old ones are.
Dave
GOD, Family, career
Dave_E is offline
post #10 of 11 Old 09-16-2013
manatee's Avatar
Is it not possible to plug the hole from outside (tennis ball, small rubber ball...) until you can insert the internal plug?
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
B&G Hydra II Speedo bils Gear & Maintenance 2 10-06-2007 09:23 AM
