What is this stuff in my bilge? - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 09-21-2013
MarkofSeaLife's Avatar
Dock
Re: What is this stuff in my bilge?
I would think its sea salt. It gets in there and evaportes to those lumps and crystals.
The guess would be that there is a very small amount of sea water getting in somehow (bilges are like majic that way) and its evaportating.
zeehag likes this.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #12 of 13 Old 09-21-2013
snake charmer, cat herder
zeehag's Avatar
i fyou keep your boat in salt water you will have salts in your bilges. some is sea salt and some is salt of whatever else you have in there.
formosa 41, cruising tropics
zeehag is offline
post #13 of 13 Old 09-21-2013
Dock
If yoouur boat is stable at a marina etc, you could run a bead of silicon arpound the area to build a small dam. then you will know if the water is oozing from the keel bolt or not.
zeehag likes this.
Sea Life
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
Stuff no one will ever see... Kiltmadoc General Discussion (sailing related) 21 06-18-2010 04:50 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Bilge mold and where do I get that black sealing stuff... Hargadoo Gear & Maintenance 5 11-24-2006 09:02 PM
