Boat paint, and color. - Page 2 - SailNet Community
post #11 of 18 Old 09-24-2013 Thread Starter
Son of Njord
Re: Boat paint, and color.
Siri is a pervert.
Thermophile is offline
post #12 of 18 Old 09-24-2013 Thread Starter
Son of Njord
Originally Posted by jimgo View Post
My boat has a painted hull and bottom. She previously had a white hull, but now it is a dark green. The problem with paint is that it requires periodic maintenance. I can't tell you how long ago my hull was painted, but I suspect it was 5 to 10 years ago. There are blisters, and places where the paint is clearly needing to be refinished. I have read many times, and have now seen firsthand, that once you paint, you can't go back. I love the look of the green hull, but if I were doing it over again, I would probably investigate having a colored gelcoat put on top instead. Now that we have paint, the only thing to do is continue painting.
So can you only get the colored gelcoating done when thr boat is new orrr?
post #13 of 18 Old 09-24-2013
GeorgeB's Avatar
The pigments in colored gelcote are notoriously susceptible to sun fading and oxidation. These hulls need a lot of polishing and waxing to stay nice. You have many more color options if you use an epoxy paint such as Awlgrip. You can epoxy paint at any time (unlike gelcote pigments). Like any painting project, this requires a lot of prep work and access to a spray booth for that mirror finish. And, as said before, the paint is subject to scratches (the white will show through) and the mars and rubs encountered at the dock. You will not have much success buffing out at “problem” on an epoxy painted hull. On the other hand, there isn’t anything as pretty as a dark blue hull (with the possible exception of a dark red one).
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is offline
post #14 of 18 Old 09-24-2013
Asleep at the wheel
jimgo's Avatar
As you can see from George's post, there are advantages and disadvantages to anything. Most people go with white gelcoat hulls because they are easy to maintain and cooler in the summertime. Also, not all manufacturers let you order the boat with a colored hull.
All that being said, I do agree with George that the colored hull is sharp. I don't think that, if my next boat had a painted hull, I would let that stop me from buying her. But, in hindsight, I think a white hull with a nice bootstripe and pinstriping (or whatever it's called under the rub rail) and sharp canvas can look pretty good, too, and the maintenance would be less of a problem.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #15 of 18 Old 09-24-2013
Asleep at the wheel
jimgo's Avatar
Here are some examples of what we're talking about:
Dock Rash: (from bumpers and fingers/piers rubbing against the hull)
Peeling/blistering paint:
Click on any of the pictures for larger versions. The peeling one is kind of hard to see until you look near the bow and under the rub rail.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #16 of 18 Old 09-24-2013
tommays's Avatar
I don't know were your starting point is BUT paint is a last resort and i have no regret even with the massive amount of work it took as i was well past any reasonable restore of the gel
Gelcoat on a big boat is and even MORE MASSIVE amount of work as all that shine comes from wet-sanding and buffing
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #17 of 18 Old 09-25-2013 Thread Starter
Son of Njord
A ton of great info! Thanks everyone.
post #18 of 18 Old 09-25-2013
Bare with me as I am new to the maintenance aspect of boating. How can you tell if the hull has been painted or has a color gelcoat on it?
jmurdock is offline
Why do we paint the bottom a different color? WesterlyPageant Gear & Maintenance 11 02-07-2009 10:37 AM
I want to paint my boat kimbersleep Gear & Maintenance 11 06-24-2008 09:50 AM
boat paint obiec Gear & Maintenance 11 04-22-2002 11:45 AM
boat paint obiec General Discussion (sailing related) 1 04-17-2002 05:21 PM
boat paint obiec Cruising & Liveaboard Forum 0 04-15-2002 08:53 PM
