Jib Roller Furler - SailNet Community
post #1 of 7 Old 09-24-2013 Thread Starter
NautiG's Avatar
Jib Roller Furler
Hi all,
I was given a used roller furler and want to install it when I haul out this winter. I have no experience with roller furlers and want to figure out whether I can install it myself, or need to get a rigger to do it. I'm trying to figure out the manufacturer and find installation instructions. Unfortunately, the markings on the furler have mostly worn off. Here are two pictures of the furler:
Any help with IDing the furler, or installation advice is appreciated.
Thanks, Scott
Gemini Catamaran Split Decision
NautiG is offline
post #2 of 7 Old 09-24-2013
overbored's Avatar
Re: Jib Roller Furler
It is a Plastimo Furler but dont know much about them. they are still in business.
"GOLD RUSH" PRINDLE 16
overbored is offline
The Following User Says Thank You to overbored For This Useful Post:
NautiG (09-24-2013)
post #3 of 7 Old 09-24-2013
Asleep at the wheel
jimgo's Avatar
This might be useful:
Plastimo - Headsail reefing system : chainplates or turnbuckle mounting ?
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #4 of 7 Old 09-25-2013
paulk's Avatar
We like to do our own work on our boat, but to install a furler, we had riggers do it. Stuff that will take you hours to figure out, they will have done twenty times already. A good outfit will know the foibles of different manufacturers, and will know what needs to be done to make it work properly. You could spend two full days (an entire weekend!) installing your secondhand unit, and not have it working exactly right, and not know it, and not know why. Having professionals do it avoids these problems. It isn't THAT expensive, considering that you didn't pay full price for a second hand unit.
paulk is offline
post #5 of 7 Old 09-26-2013 Thread Starter
NautiG's Avatar
Paul,
I appreciate your opinion, but even if I decide to have someone else install the furler, I'd like to at least educate myself about it, so I know what is involved with the installation and how the furler works. Especially having no prior experience with furlers.
I've found an installation manual for Plastimo furlers:
www.bluemoment.com/manuals/plastimo_s_series_roller_reefing.pdf
I'm trying to identify the model # of my furler, but it doesn't look like anything I've been able to find online. Plastimo seems to have a reputation for building cheaper furlers for smaller boats. My furler drum looks larger and more heavy duty (stainless steel instead of plastic and aluminum) than anything I've found online. The furler came off a cruising sailboat from another country. Plastimo doesn't even have a dealer in the US.
Edit: I think I have the chainplate version of an older model plastimo.
Thanks, Scott
NautiG is offline
post #6 of 7 Old 09-26-2013
Tartan 27' owner
CalebD's Avatar
Scott,
You are absolutely right that you should know how your furler works. Especially how and where it is supposed to be lubed.
The first time it hangs up you'll be glad you know what to do.
Everybody has one:
CalebD is online now
post #7 of 7 Old 09-26-2013
IMO you WILL need a rigger, UNLESS, the stay is the right size for your boat. That said, ask them what the condition of this furler is, I would bet it is fine, but if the parts are no longer available, then a lot of work and money could go for something you might only get a couple years out of.
sanssouci is offline
Help with my roller furler abrahamx Gear & Maintenance 3 07-17-2013 11:17 AM
Roller Furler for Alberg 35 Lake Erie Monster Gear & Maintenance 6 04-15-2013 05:14 PM
Can you identify my roller furler? aloneinthewoods Gear & Maintenance 3 07-28-2011 02:23 PM
Roller Furler ID? (w/Pic) Seafire327 Gear & Maintenance 6 05-21-2009 09:28 PM
Anyone know how to set up this roller furler somers12 General Discussion (sailing related) 2 05-26-2008 02:52 PM
