Floor leaks in dinghy - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 09-25-2013
PAULCR1's Avatar
Grumpy Cat
PAULCR1 is on a distinguished road
We just bought a used dinghy. It has an inflatable floor that sits on top of an inflatable keel. The top side of the floor has a series of pinhole leaks. Is there a fix that anyone knows of for this, like 'fix a flat. The dinghy is hypalon and I am assuming that the floor is the same.
Thanx
Theodore Roosevelt said “In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.”
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 09-25-2013
pauloman's Avatar
pauloman is on a distinguished road
Re: Floor leaks in dinghy
I have used Aluthane - a mcu aluminum paint on a weathered plastic tarp used as a boat cover - sealed it nicely. I bit stiff but not an issue for your material. google aluthane
paul
epoxy supplier
  #3
Old 09-25-2013
nrb nrb is offline
nrb is on a distinguished road
Second the Aluthane comment
  #4
Old 09-26-2013
seaner97 is on a distinguished road
There is some stuff you put in then roll the boat around and reinflate that does exactly this. Works pretty well. Forget the name, but was easy to find at Hamilton marine or west marine.
  #5
Old 09-26-2013
Inflatable boat sealant- duh. West sells it for about 60$
  #6
Old 09-26-2013
Capt Len is on a distinguished road
Tried that once.. Not impressed. Prepping and painting floor with Hypalon could work.
You may post attachments
You may edit your posts
make a inflatable Dinghy Floor? bratzcpa Gear & Maintenance 2 04-10-2013 06:42 PM
Rebuilding Wood Floor On Dinghy AdamHowie Gear & Maintenance 13 07-05-2011 11:09 PM
Dinghy Floor mxtommy Gear & Maintenance 15 02-03-2011 07:19 PM
High Pressure V Floor Dinghy lancelot9898 Gear & Maintenance 9 02-21-2009 03:04 AM
islander 28 leaks at port floor, aft of keel Paul Comte Islander 0 04-29-2006 08:45 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
