Two cheapo material questions - galvanized solar/radar arch and ext plywood sole/floo - SailNet Community
 2Likes
post #1 of 12 Old 09-25-2013 Thread Starter
Hello all,
Pondering this winter's refit and adding up some costs and then feeling nauseous.
I'm planning on pulling the (damp/very spongy) cabin sole from my Triton and putting in transverse floors + a new plywood sole. I'm planning on doing this with non-marine grade plywood...I was pondering something like this
Everything will end up encapsulated in epoxy. The floors will be glassed against the bilge and the sole will be glass against the hull. It all will be a lot stiffer than what is there now.
Any reason to use Marine plywood? It seems like this will be much stiffer than the original so I can't really figure out why I should.
ALSO
I'm looking into putting an arch on the stern for a fairly wide 100w solar panel, and potentially for a radar. Since my mast mounted VHF is seemingly not working, I was also thinking it might be nice to have a VHF antenna on the arch so that if something went wrong it would be easier to deal with.
I've been looking into stainless steel arches and they are pretty expensive. I'm pondering galvanized steel pipe and then painting it instead. I could cut it myself and have someone weld it together for me. Any reason not to go that route? It seems like the cost savings would be significant.
Any thoughts?
Thanks!
Paul
sully75 is offline
post #2 of 12 Old 09-25-2013
Old as Dirt!
svHyLyte's Avatar
Re: Two cheapo material questions - galvanized solar/radar arch and ext plywood sole/
Originally Posted by sully75 View Post
Hello all,
Pondering this winter's refit and adding up some costs and then feeling nauseous....
Any thoughts?
Thanks!
Paul
Paul,
You might want to speak with Ben Zartman, or read his latest article in the current edition of Good Old Boat with respect to using galvanized steel pipe for anything above deck before going ahead. See also, Cruising with the Zartman Family | A Small Boat, A Growing Family, A Big Dream
svHyLyte is offline
post #3 of 12 Old 09-25-2013
Skipper Jer's Avatar
When you weld the pipe the galvanizing inside the pipe will burn off. The rust will start inside the pipe which cannot be inspected.
OPossumTX likes this.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #4 of 12 Old 09-25-2013
Remember you're a womble
PaulinVictoria's Avatar
The metal will rust. The ply will rot. Next
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 12 Old 09-26-2013
I would expect wood to last longer than galvanized, and aluminum a little longer maybe.
If properly anodized aluminum is impervious if not Ha Ha.
Zen is a matter of recognizing reality.
desert rat is offline
post #6 of 12 Old 09-26-2013
tdw
Super Fuzzy Moderator
tdw's Avatar
CMeme's point re galvanising burning off is why gal tube is usually joined by threaded connectors. At least I think thats the case. In reality there is no good reason not to use Gal pipe other than that it will not look as pretty and its somewhat heavier than stainless. Plenty of boats (oh crikey I'm starting to sound like BS) have used gal for lifeline staunchions and have done so quite successfuly.
Provided the ply is encased in epoxy and I do mean encased (endgrain this means you !!) then building grade waterproof ply will do the job for you but if any fresh water gets into the ply itself then yep, Paul is correct, it will rot. However done right it will probably be OK, particularly if you keep your bilges dry.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #7 of 12 Old 09-26-2013
Galvi pipe is much heavier and even if galvanized after welding has a limited life. Don't ask how I know this. Aluminium is a better choice. or ss if you can dumpster like I do. Pay a welder and do it right. If you can find an aircraft repair shop look for floor panels from big wrecked planes(747, 737 etc) Honeycombed plastic 5/8 boards. easy cut and glassed.Worth the time scrounging.
Capt Len is offline
post #8 of 12 Old 09-26-2013
Senior Moment Member
SloopJonB's Avatar
It's best not to have any sort of mild steel on a boat. If it's magnetic, leave it ashore - steel boats excluded of course.
Good quality exterior ply works fine inside boats, especially if it is epoxy coated. It is particularly important to ensure the edges are sealed. I've used it any number of times with nary a problem.
My current 36 Y/O boat has an interior constructed largely of it, much of it not even painted (yet) in the hidden areas and there are absolutely no problem areas.
SloopJonB is online now
post #9 of 12 Old 09-26-2013
Less Senior Senior Member
Did mine with marine ply and teak and quartersawn tng 3/8 flooring. Any gap or defect in the epoxy (virtually guaranteed to happen) will lead to either rot, mold or standard glue delam in the Home Depot ply. The money you save on the plywood you will lose on doing it again unless you plan to sell the boat and make it someone else's problem in the next few years.
Ocean- that which covers 3/4 of a world made for man, who has no gills.
seaner97 is offline
post #10 of 12 Old 09-29-2013
I have to do my Sole this spring as It has gone to H the second time.
I am going to use a Fiberglass panel you can buy and glue to a 3/8 tongue and groove plywood.
Soak the edges of the patterned plywood with Penetrating epoxy.
This will help eliminate rot around the edges also will aid in getting a strong bond to the hull.
I am the going to apply T&G hardwood using epoxy paste using a colloidal thickener, from West System.
I had the description written down for you twice; but trying to do too much I lost it each time.
So I'm attaching a Pix of my boat Risqué at a dock at Harbor Beach, MI.
captjim6 is offline
PSC 31 Arch for solar and wind generator jubliado61 Pacific Seacraft 4 04-04-2010 02:04 PM
Cost of a radar arch Newport41 Gear & Maintenance 9 05-29-2009 02:45 AM
Cargo Shift Radar Arch - FL WBurgner Ericson 0 08-12-2007 03:21 PM
Newport 41 MK2 Radar Arch Redline4Life Newport 1 03-29-2007 03:34 AM
Newport 41 radar arch! Redline4Life Gear & Maintenance 0 02-08-2007 12:44 AM
