Stained interior teak - SailNet Community
post #1 of 11 Old 09-26-2013 Thread Starter
I'm wondering how difficult it will be to get rid of this water stain.
Can it be repaired or am I stuck with it? How would you proceed?
Thanks!
Loki9 is offline
post #2 of 11 Old 09-26-2013
Re: Stained interior teak
good question, you can always try a teak cleaning kit, I used the one by aurora and my teak came out real nice
not sure what it will do to a water stain though
good luck
FRED
fred1diver is offline
post #3 of 11 Old 09-26-2013
Tartan 27' owner
CalebD's Avatar
One worry is that that piece of wood is likely a veneered ply.
Heavy sanding is not possible in that case.
did water get in behind that panel?
The stains look to be about the height where objects on the nav table
could chafe it.
Have you tried all the conventional cleaners?
Oxalyic acid (Barkeeper's Friend) is in the one part teak cleaners sold at WM.
It may remove lighten up some of the stains.
Light sanding with a fine grit (#220 or higher), re-oil and/or varnish
and hope for the best.
Or... paint it white!
Everybody has one:
CalebD is offline
post #4 of 11 Old 09-26-2013
azguy's Avatar
Try Wood bleach, AKA oxalic acid
Oxalic Acid Wood Bleach | Real Milk Paint
azguy is offline
post #5 of 11 Old 09-26-2013
Tartan 27' owner
CalebD's Avatar
Barkeeper's Friend is cheaper than any "marine" oxalic acid.
A can is about $5 and you can clean a lot of different things with it.
Mix with water - apply - wait - wash off.
Simple.
Everybody has one:
CalebD is offline
post #6 of 11 Old 09-26-2013 Thread Starter
This isn't my boat, just one I'm considering, so I haven't tried removing this stain yet. The chain plate above leaked at one time, and dripped down the back of the wood in the photo. It is a veneer over ply.
Loki9 is offline
post #7 of 11 Old 09-26-2013
maybe get new veneer?
post #8 of 11 Old 09-26-2013
It's a bit of a project but completely do able. Strip the varnish off, bleach the wood, seal the wood and re varnish. I have done it in my boat and it looks brand new. Of course, I am assuming that the wood behind it is solid and not rotted.
sanssouci is offline
post #9 of 11 Old 09-26-2013
Tartan 27' owner
CalebD's Avatar
Say you are not getting rid of your A4 powered Pearson?
Everybody has one:
CalebD is offline
post #10 of 11 Old 09-26-2013 Thread Starter
Sold it last week. The P30 is a great boat, my family liked sailing so much that they insisted I get something larger that we can spend weeks at a time on.
Loki9 is offline
Teak Interior Help Mako144 Gear & Maintenance 15 06-03-2013 08:43 AM
What is the best interior Teak Oil? Petar Gear & Maintenance 14 04-29-2010 09:00 PM
Any way to lighten teak that has been stained dark? TakeFive Gear & Maintenance 8 02-01-2010 01:44 PM
Teak Oil stained the deck miggidy Gear & Maintenance 7 09-09-2009 10:27 PM
Interior Teak jongoose Cabo Rico 12 06-23-2009 12:18 AM
