Hull on a Catalina 30 - SailNet Community
post #1 of 8 Old 09-27-2013 Thread Starter
Can anyone clarify whether the hull on a Catalina 30 is solid fiberglass or cored? Looking to install a transducer and the answer will determine whether a thru-hull or in-hull transducer can be used.
armandolio is offline
post #2 of 8 Old 09-27-2013
DearPrudence's Avatar
Re: Hull on a Catalina 30
Don't know armandolio, but, if you can use an in hull transducer wouldn't it be better than drilling a hole in your boat? I just installed an in hull transducer in my 30 (AirMar 79(?) for my Garmin 740s and it works as expected.
DearPrudence is offline
post #3 of 8 Old 09-27-2013
overbored's Avatar
Call Catalina and ask for your hin number. You can use a in hull transducer in a cored hull. inner layer of core is removed and glass is remover and a layer of glass is used to seal the core edge. see instructions http://www.airmartechnology.com/uplo.../17-217-01.pdf
"GOLD RUSH" PRINDLE 16
overbored is offline
post #4 of 8 Old 09-27-2013
Dirt Free
boatpoker's Avatar
The hull is not cored .... but why drill a hole when yo can buy a shoot through transducer ?
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #5 of 8 Old 09-28-2013 Thread Starter
I agree, I do not want to drill a hole in the hull. That is why I am trying to figure out if it is solid or not. It was also explained to me that I can test the transducer/hull by placing the transducer on a bag of water (at the location of installation) and check to see if it reads the depth.
BTW, it is a 1989 Catalina 30
post #6 of 8 Old 09-28-2013
mitiempo's Avatar
Catalina did not core hulls, only decks. Very few builders cored hulls.
Brian
mitiempo is offline
post #7 of 8 Old 09-28-2013
djodenda's Avatar
Had one.. It's a solid hull
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #8 of 8 Old 09-28-2013 Thread Starter
Thank you all
Oil canning hull of older Catalina Capri 22 kcjonz Catalina 2 07-07-2013 08:16 PM
Catalina 250 hull trim caroljeanly C25 and 250 1 12-14-2011 11:04 PM
Catalina 30 thru-hull size Fstbttms Gear & Maintenance 5 12-29-2008 12:40 PM
Hull Integrity of a Sunken Catalina 36 nunzio Gear & Maintenance 27 04-28-2008 11:49 PM
1976 Catalina 27 Hull Questions catcrazy27 Gear & Maintenance 2 09-17-2007 02:55 PM
