Tea Tree Oil Recipe - Page 2 - SailNet Community
 5Likes
post #11 of 35 Old 09-30-2013
Re: Tea Tree Oil Recipe
Originally Posted by pdqaltair View Post
$7.95 for 2 ounces is better!......
Is that the Kanberra refill cost or the cost of the product you are recommending?
I pay $3.75 per ounce to refill Kanberra.
http://www.amazon.com/Kanberra-Gel-Refill-Pouch-oz/dp/B008JHX846/ref=sr_1_2?ie=UTF8&qid=1380538817&sr=8-2&keywords=kanberra+gel
Jeanneau 54DS
Minnewaska is offline
post #12 of 35 Old 10-01-2013
pdqaltair's Avatar
The thing of it is that most of the gel products (including Kanberra) are only about 8% tea tree oil.
The Walmart product is 100% tea tree oil, making the Kanberra product see to be, well, a rip-off.
I tested dehumidifiers and tea tree oil and some other things for an article....
The dehumidifier won and it wasn't close; the dehumidifier stopped the mold, the tea tree oil made it smell pretty.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #13 of 35 Old 10-01-2013
no longer reading SailNet
Alex W's Avatar
What kind of dehumidifiers did you test? I recently installed a peltier style one (EvaDry 1100), but it is too new for me to really say how well it is working. It is filling up with water which is good.
Alex W is offline
post #14 of 35 Old 10-01-2013
pdqaltair's Avatar
I was using the EVA Dry 2000 in a 32-foot catamaran, so I think you've got the size about right. It will probably want to frost in the winter, so put it on a timer (it will thaw during the day, when it is off and the sun is up).
http://sail-delmarva.blogspot.com/20...-desicant.html
I ran a hose to the sink and sat it on the stove.
post #15 of 35 Old 10-01-2013
Dehumidifiers are great when you're dockside. However, up on the hard, most aren't permitted to run power 24/7. It's the shoulder seasons that heat up the interior that I find are the greatest risk. Kanberra has been holding them off nicely. Even the product that I set out in the Fall will freeze over the winter and be instantly available as the Spring thaw occurs. Perfectly timed for when its needed.
Jeanneau 54DS
post #16 of 35 Old 10-01-2013
How much kanberra do people use for a boat on the hard in the Caribbean from mid July to end of October with no dehumidifier. I bought the 24 oz one and split it into separate containers one for each of 3 cabins 2 heads and 2 in the salon/galley. I hope it is working as I have not seen the boat since mid July. I also put some dehumidifier gel tubs around but a mechanic told me they were shot after about 4 weeks.
neilsty is offline
post #17 of 35 Old 10-01-2013
chef2sail's Avatar
Kanberra Gel Online Store - Kanberra Gel
USent from my iPad
99 dollars.....24 oz....by last bag lasted 2+ years. Well worth it. No need to experiment
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #18 of 35 Old 10-02-2013
pdqaltair's Avatar
True enough, and deiscant (CaCl2) is impractical (lots is needed).
However, I have been experimenting with running the dehumidifier off the solar panels, which works fine if I set the cycle short (4 hours per day) and run it off the 12v side. That is enough to keep the RH ~ 50% with the boat sealed up.
I stay in the water all winter (a bit more humid I'm sure); dehumidifiers are probably a better answer in that case.
post #19 of 35 Old 10-02-2013
I presume that is the stuff in Damp Rid? I do that too. I just buy the refill for about $5 that reloads about 8 or 10 baskets. Each will collect about a cup of water over the winter and I sit them in each sink so they would drain overboard if they froze and broke. I doubt that's really all that meaningful, but its cheap. Better than nothing, but no replacement for Kanberra, IMO.
At a mooring or slip? Seems a slip would provide power. If you stay in the water at our marina (no liveaboards), you get a meter and pay for what you use.
Jeanneau 54DS
post #20 of 35 Old 10-02-2013
T37Chef's Avatar
Um, you know we make enough fruit jellies that I bet I could sub out some tea tree oil, the hang up would be how to get to diffuse/release?
Shawn
T37Chef is offline
The most versatile recipe's ever bwalker42 Provisioning 7 10-11-2013 05:09 PM
The best bread recipe's II bwalker42 Provisioning 25 10-07-2013 09:53 AM
Ice Cream Recipe twagg7 Provisioning 6 11-04-2004 12:19 PM
"Sundowner" recipe backdraft General Discussion (sailing related) 1 11-21-2000 04:11 PM
