Chain plate or impact. - Page 2 - SailNet Community
 10Likes
post #11 of 39 Old 10-01-2013
Jnoiur Mebemr
StormBay's Avatar
Re: Chain plate or impact.
If the plate let loose a little it would put pressure out on the hull as the rig pulls it inward.
Yu & Frank
StormBay is offline
post #12 of 39 Old 10-01-2013
Senior Moment Member
SloopJonB's Avatar
That looks like impact from the INSIDE. A hit from outside that could cause that sort of crazing would be unlikely to have totally missed the teak rails. I would think there would also be a more distinct primary impact point - down to the glass - instead of just crazed gelcoat.
Could be caused by the expansion of corrosion inside those miserable glassed in chains.
Either way, happy grinding.
StormBay likes this.
SloopJonB is offline
post #13 of 39 Old 10-02-2013 Thread Starter
chucklesR's Avatar
Inside impact didn't happen.
There was a leak, previous owner silicone'd the crap out it.
The chain plates (3) are tied into a horizontal grid - which might explain the 't' shape.
The storm in June - Six Tornadoes Confirmed on June 13th
High water and a gust could have caused it, just don't know - if I took a hammer and hit it I'm real sure it look the same. My insurance co confirms if impact it's covered, if plates pulling it's not, unless the impact loosened the plates.
That's why I've got a thermal camera coming - no guessing and a certified surveyor to put in writing what caused what when.
chucklesR is offline
post #14 of 39 Old 10-02-2013
Thanks Courtney.
Not much of a way for it to have been impact from inside, but an impact to the rub rail and possibly the cap rail could have flexed the hull in around the chainplate. That would make it look like it was pushing out. When is your surveyor coming?
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #15 of 39 Old 10-02-2013 Thread Starter
chucklesR's Avatar
Hopefully he's coming Wednesday. It's a hook up I happened on when Beth Leonard (yes, that Beth) gave me her card at the rigging talk during the SSCA GAM last weekend - she told me she might know someone.
I've been going crazy trying to find a method of non-destructive testing - apparently there is a guy in Trinadad that x-ray's chain plates for 800 bucks, but no one nearer - or at least they don't advertise or even admit it.
I can't just hole saw a core out because doing so might in fact destroy any evidence that it's not impact related.
Even my insurance agent is telling me to proceed cautiously towards proof. I've been gathering wind/rain and tide stuff to show impact is and was possible.
post #16 of 39 Old 10-02-2013
If it were 'chainplate' stress, wouldn't it have cracked the inside liner also??????
AirborneSF is offline
post #17 of 39 Old 10-02-2013
Asleep at the wheel
jimgo's Avatar
It might be worth a call:
Medical Equipment Rental Results for X-Ray Machine Baltimore Maryland | Rent It Today
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #18 of 39 Old 10-02-2013 Thread Starter
chucklesR's Avatar
There is no inside liner - the plates are embedded in the hull and then have cabinetry built over the area.
Only way to get to it is to disassemble the inside.
Here's a shot from the inside - you can see I had some long time ago water damage (more than 9 years the PO owned the boat).
post #19 of 39 Old 10-02-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
looks like chainplate stress to me. My Seasprite has it on both sides where the chainplates are embedded. One of the reasons they are coming out
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #20 of 39 Old 10-07-2013
Thanks Courtney.
Chuckles- Any updates?
T34C is offline
Chain Plate Replacement casey1999 Gear & Maintenance 35 05-21-2013 11:53 PM
Chain plate metal bad davidpm Gear & Maintenance 11 10-26-2011 12:08 PM
Chain plate help atlanticcruiser Gear & Maintenance 15 12-20-2010 12:46 PM
Chain Plate (Not) davidpm Gear & Maintenance 2 04-14-2009 06:52 AM
Chain Plate Replacement jsutor Gear & Maintenance 1 04-30-2005 03:40 PM
