Yanmar 3YM20 sea water pump leak...repair or replace? - SailNet Community
 2Likes
  • 2 Post By azguy
post #1 of 5 Old 09-30-2013 Thread Starter
NewportNewbie's Avatar
Got a leaking sea water pump on my yanmar 3YM20. The leak is from the rear f the pump behind the impeller. I have read you can repair them. Is it an easy job? The replacement pump is about $270 from my local yanmar dealer. I know the rebuild is cheaper but how long will it last and will it be less hassle to replace the whole unit?
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 5 Old 09-30-2013
overbored's Avatar
Re: Yanmar 3YM20 sea water pump leak...repair or replace?
depends on the problem if it is just a seal then it is cheap but if the shaft is worn then a new seal will help but might not fix it for long. the shaft is about $100 and can be removed by removing the pulley and tapping out the shaft with a soft hammer. it does take a little mechanical know how. buying a new one is a easier and if yours requires more then a seal may be the better way to go
"GOLD RUSH" PRINDLE 16
overbored is online now
post #3 of 5 Old 09-30-2013
azguy's Avatar
Buy a new one to replace the current one and then rebuild the old one in case of emergencies
RobGallagher and Seaduction like this.
azguy is offline
post #4 of 5 Old 09-30-2013 Thread Starter
Thx. I think I will buy a new one and keep the old as a spare.
post #5 of 5 Old 09-30-2013
trantor12020's Avatar
What i did was buy a new shaft and the bearings, oil seal, spacer, c-clips, o-rings and disk, LH nut. Re Built both shafts (new and old). Fit new into pump and keep old rebuild as spares. Only bought shaft, LH nut, disk and spacer from Yanmar dealer. Oil seals, o-ring and bearings from auto supply shop. Use waterproof grease when rebuilding pump.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
yanmar 3ym20 raw water pump Ceezed Diesel 4 11-02-2011 11:15 PM
C&C 32 raw water pump for 2gm yanmar bigchump C & C 6 04-15-2011 09:55 AM
Yanmar 3ym20 pre mature water pump failure jbrockpiano Diesel 7 09-19-2010 10:25 AM
Replace fresh water pump? SteveInMD Diesel 2 04-22-2010 08:54 PM
raw water pump leak on Yanmar 3Gm30F gsyversen Gear & Maintenance 24 06-13-2008 02:34 AM
