09-13-2004
Super Moderator
removing stays
Yes, you can replace the rigging while the mast is still in place. With a deck stepped mast when you do remove the fore- or backstay, you need to temporary use the main halyard (or jib halyard for the forestay) to act as a temproary stay and then go up the mast on your other halyard. You also can remove shrouds two at a time in pairs, although it is a good idea when you remove the uppers to stay the upper end of mast with tight lines if you are in a bouncy anchorage.
It is also a good idea to use tape to mark the point on the turnbuckle where the threads (top and bottom) of the turnbuckle enter the screw body so that the rigging shop can exactly figure out how long your shrouds were in the adjusted position. I will say that it is much easier to do this with the mast on the ground and that the cost to remove and replace the mast is not all that expensive. I just replaced my standing rigging on my boat.
