Composting Toilets vs. Holding Tank - Page 12 - SailNet Community
 28Likes
post #111 of 114 Old 11-20-2013
mitiempo's Avatar
Re: Composting Toilets vs. Holding Tank
Marine (or RV) Tp is designed to dissolve far easier than conventional household Tp.
Easiest solution if Tp is a problem with any head system is to not put it in the head - as is done in many countries.
Brian
mitiempo is offline
post #112 of 114 Old 11-20-2013
Any single ply TP is a perfectly suitable substitute for marketed marine TP.
So, we've talked about TP and diarrhea. Skid marks? Think about it. No flush water.
Jeanneau 54DS
Minnewaska is offline
post #113 of 114 Old 11-20-2013
captain jack's Avatar
lol
captain jack is offline
post #114 of 114 Old 11-21-2013
Originally Posted by casey1999 View Post
Can someone with "compost toilets" explain the following:
1. Can you put toilet paper in the composter? What if someone uses a lot of toilet paper- what happens?
2. What if a crew member has diarrhea? Seems like that would be a mess.
#1 - You can put TP in the composter, but it will fill up faster. The other thing to consider is if you dump your compost in the woods (like me) or out at sea, you don't want to be leaving paper there. We use a small garbage can with lid lined with a plastic bag for all paper. When it's full we just tie it and dispose of it with our trash.
#2 - This may be a problem as it might not go directly in the hole to the composting chamber. We always keep a roll of paper towels and a spray bottle of vinegar solution beside the toilet just in case anyone "misses". Hasn't happened so far
Vindö 50
copacabana is offline
Tags
catalina 27 , composting toilet , head , holding tank , liveaboard
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Composting Toilets Pendle Gear & Maintenance 15 09-22-2010 08:47 PM
Holding Tank leterip Announcements and Suggestions Box 2 12-23-2008 10:03 AM
Composting Toilets tumblebug General Discussion (sailing related) 1 02-10-2008 02:39 PM
Composting Toilets tjvanginkel Gear & Maintenance 23 09-23-2007 11:43 AM
