Composting Toilets vs. Holding Tank - Page 4 - SailNet Community
 28Likes
post #31 of 114 Old 10-03-2013
T37Chef's Avatar
Re: Composting Toilets vs. Holding Tank
Any thoughts on Lectra San?
Shawn
T37Chef is offline
post #32 of 114 Old 10-03-2013
MikeOReilly's Avatar
You could be right about the functional impact. I haven't done or seen an analysis that would answer the question if which is the least damaging. It will be small, either way.
Where I cruise there's lots of opportunity for the shallow hole solution, but I grant that is not always possible. Hopefully in those urban areas people can head out to sea for a standard dump.
Why go fast, when you can go slow.
MikeOReilly is online now
post #33 of 114 Old 10-03-2013
Godot's Avatar
It sounds to me about as close to the perfect solution as you can find. Except I don't believe you can use it in zero discharge waters.
Godot is offline
post #34 of 114 Old 10-03-2013
4arch's Avatar
Weve had a composting head for three years now. We wanted very much to like it and in fact did love it for the first year or so. At first having to constantly empty the liquid container seemed a small price to pay for not having to deal with holding tanks and pump-outs, but now were much less convinced. After another recent infestation, weve come very close to deciding to remove the composter and to reinstall a conventional marine head and holding tank. Weve had fruit fly and fungus infestations intermittently and when they occur its an absolutely disgusting cleanup job. I think the medium was getting and staying too damp and we've rectified that to some degree (part of which means not using the toilet on port tack!), but the next time I find fungus or fruit flies - I'm done!
As for the LectraSan, I've heard them pretty widely praised for areas that aren't NDZ. If you're going into NDZ areas you have to keep the regular holding tank in parallel, which takes up a lot of space. They're also very expensive.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is offline
post #35 of 114 Old 10-03-2013
To the OP: You have received a great deal of information and links to previous threads where this has been discussed at length. Those who have composting heads seem generally pleased with them. Remember though, that this is not a random sampling by any means and the reality is that probably 99.9 % of all boats out there that have a head do have some sort of holding tank system. The marine head/holding tank system works acceptably well for the vast majority of boaters, and as has been mentioned before, a composting system not going to be a plus when it comes time to sell your present boat.
jgeissinger is offline
post #36 of 114 Old 10-03-2013
T37Chef's Avatar
I believe you can still plumb them to a holding tank if needed for those zero discharge zones like Herring Bay.
Shawn
T37Chef is offline
post #37 of 114 Old 10-03-2013
Originally Posted by MikeOReilly View Post
Hmmm, not sure what you mean Minn. Have you used one? There's nothing very odd or gross about it. The only real difference is men have to sit. And you have to open the trap door. Everything else happens as-per normal.
I have. I've also used an outhouse and porta potty. They're all gross, by common standards. Doesn't stop me, but I know plenty who won't use any of the above. Period.
If you can't fully compost the waste (which takes ~3 months I've read) then it should be dumped out at sea, just like a normal marine head (once you're out past legal limit).....
If you're depositing in it every day, the moment you empty it you have nearly uncomposted waste in the mix. What would you do with it aboard to let it compost for 3 months? Therefore, dumping past the limit is really the only option and I doubt their are many that find themselves in legal dumping areas often enough to be practical. Therefore, the same raw sewage from yesterday's deposit goes straight in the trash I suspect.
Jeanneau 54DS
Minnewaska is offline
post #38 of 114 Old 10-03-2013
davidpm's Avatar
I think that what some folks do is have a spare bucket that is sealed and just thrown in the hold and disposed of after a couple months.
davidpm is offline
post #39 of 114 Old 10-03-2013
Interesting. News to me that it will continue to decompose without air. That right?
Jeanneau 54DS
post #40 of 114 Old 10-03-2013
fryewe's Avatar
Put a half cup of diatomaceous earth in the bucket with each new "charge" of peat moss. It will eliminate all insect larvae. Available at any big box garden shop.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
Tags
catalina 27 , composting toilet , head , holding tank , liveaboard
Convert existing steel freshwater tank to blackwater holding tank? patrickstickler General Discussion (sailing related) 7 09-24-2010 07:55 PM
Composting Toilets Pendle Gear & Maintenance 15 09-22-2010 08:47 PM
Holding Tank leterip Announcements and Suggestions Box 2 12-23-2008 10:03 AM
Composting Toilets tumblebug General Discussion (sailing related) 1 02-10-2008 02:39 PM
Composting Toilets tjvanginkel Gear & Maintenance 23 09-23-2007 11:43 AM
