Rigging a tack for a drifter - SailNet Community
post #1 of 3 Old 09-13-2004 Thread Starter
Full-time Cruiser
jonlgauthier's Avatar
My sloop has a furling forestay. I also have a drifter with a wire luff that we can rarely use because the only attachment point for the tack is behind the furler - inside the forestay. The halyard for the drifter is run thru a block at the head of the mast attached to a bail that''s above the forestay and the swivel assembly of the foil - normal for a spinnaker halyard. But the inside tack point prevents me from being able to properly jibe the drifter. I should also state that the drifter attaches only at the tack and the head - no luff in the foil or hanks on the forstay. And the foot of the sail is down all the way to the tack, so there''s no high foot like an asymm.
The furler/forestay is attached to a "chainplate" at the bow, and it has three attachment points - one forward and about 3 or 4" the bow deck, and two just behind (2 or 3") that are just barely above deck level. Right now the roller furler drum is attached at the forward position.
The options I have are to re-rig the forestay and attach it to the aft point. That would bring the stay back somewhat, moving the center of effort of the jib back as well. It probably won''t be enough to affect handling or require re-cutting my headsails. But it still won''t project the tack of the drifter out beyond the pulpit, so care would be still be needed when jibing. The other option is to rig some type of pole as a sprit.
Any ideas on my options - other than trading the drifter for a high-footed asymmetrical spinnaker? Would the loads be too great for a sprit pole without some type of downward "tack support" halfway down the bow, sort of like a miniature model of a tall ship''s bow with a long sprit?
jonlgauthier is offline
post #2 of 3 Old 09-14-2004
Moderator
Jeff_H's Avatar
My only question is ''Do you have a bow roller?'' Very often people will use the pin in their bow rollers as an attachement point for a drifter or assymetrical cruising chute.
Jeff_H is online now
post #3 of 3 Old 09-14-2004 Thread Starter
Full-time Cruiser
Yes, but it''s off center. That would affect trim slightly, but probably not enough to really notice. My initial concern was that it may not take the upward force very well, but it''s worth a try.
And, of course, I have to make sure the luff and the sheets don''t get tangled in the bow nav light mounted on the pulpit. As they say, every boat is a compromise...
Major Tuning the Rigging RookieHunter Learning to Sail 18 10-03-2007 10:50 AM
Standing Rigging Cal 33 dshearn Gear & Maintenance 2 07-18-2004 07:42 AM
looking for help up wind mcgreggor Learning to Sail 5 02-16-2004 12:58 AM
Standing Rigging Question gwp Gear & Maintenance 5 01-23-2004 03:45 AM
Another rigging question sailorman_10 Gear & Maintenance 3 05-21-2002 09:40 AM
