Shroud Attachment - Page 2 - SailNet Community
 4Likes
post #11 of 13 Old 10-04-2013
Re: Shroud Attachment
Originally Posted by FirstCandC View Post
I understand your point about the tangs. I have one wire that is frayed above the turnbuckle, and would like to replace it. I do not feel comfortable sailing in moderate winds with this one frayed shroud.
Am I right in assuming the tangs will need to be removed for inspection? If so, then I may as well hang it up for the season, and the boat has only been in the water for six months.
Then replace the damaged shroud (or the pair)
You can inspect with the mast up - but it's easier done with the mast down.
You should consider replacing the rest of the standing rigging in a not to distant future.
knuterikt is online now
The Following User Says Thank You to knuterikt For This Useful Post:
FirstCandC (10-04-2013)
post #12 of 13 Old 10-04-2013
Liquorice's Avatar
just out of interest, I have a C&C 26 (1ft shorter than yours) and replaced all standing rigging, including turnbuckles, a couple of seasons ago. (backstay; forestay; 2 cap shrouds and 2 lower shrouds - I note you have 4 lower shrouds).
Cost was $1500 CDN, so your going to be in the $2K neibourhood to replace
it all.
sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #13 of 13 Old 10-05-2013
If you have one shroud that's failed then the rest are probably not far behind. Been there done that. I replaced mine myself for at least 50% cheaper
Why don't you do them yourself with norseman or sta-loks?....It's easy and you will save a sh**load.
What's up with the dufus spam above?? Go get him mods
benesailor is offline
Shroud attachment location at the chainplates c_witch Gear & Maintenance 8 06-25-2012 02:09 PM
Best hardware for this attachment? itsaboat General Discussion (sailing related) 5 02-25-2012 08:06 AM
Halyard attachment. deniseO30 Gear & Maintenance 1 05-26-2011 10:05 AM
vang attachment bluwateronly Gear & Maintenance 3 01-27-2009 11:10 PM
Forestay Attachment jkolle Gear & Maintenance 1 06-16-2006 05:56 AM
