I am replacing some worn sheaves and running rigging on my CS36T. I noticed that the original setup on this boat has a 4:1 block and tackle inside the boom for the outhaul. I'm thinking of just getting rid of the block and tackle and running straight line. All lines are led aft to cleats and winches. Any reason why I shouldn't get rid of the block and tackle? I feel like it just gets in the way, could potentially snag one of the reefing lines and is impossible to service. I should be able to get plenty of leverage with a winch, am I missing something?
Hmm.. that's something to consider. Although I'm not sure that's reason the manufacturer installed the blocks. The reef lines don't have the block and tackle system. And although they don't see the same loads I would bet that they aren't too far off. I want to say the purchase is there more for racers who want adjust the outhaul more frequently and quickly but I could be wrong.
Lots of boat with direct outhaul and reef lines.
Unless the sheave at the goose neck is weaker than the sheave at the boom end it should not be any problem.
The load at boom end sheave is 2x the load of the rope (180 degree angle)
At the goose neck sheave the load is 1.41x (90 degree angle)
I find it hard to ease the outhaul in nicely controlled amounts when it is run directly with no mechanical advantage to a clutch. The main on my 29' boat is probably half the size of the main on your 36' boat.
With the 5:1 tackle on my boat it is pretty easy to make small adjustments.
Mine is a little bit larger than the OP's it's 38'
The 1:1 outhaul go through a clutch to a winch.
If easing under load is a problem just take some turns on the winch drum before opening the clutch. Adjust and close the clutch.
Related Threads
1.7M posts
173.8K members
Since 1990
