Interlux Schooner vs. Sikkens Cetol - Page 3 - SailNet Community
 14Likes
post #21 of 47 Old 10-06-2013
Markwesti's Avatar
Re: Interlux Schooner vs. Sikkens Cetol
Hey StormBay , I really like your Cetol job with the natural . Makes me wish I started with the natural , as I use the Cetol light . And yes it's orange . I think I'm going to buy a can of the natural, thanks to your nice pics. Thanks!
Markwesti is offline
post #22 of 47 Old 10-06-2013
bljones's Avatar
LOL- Cetol recommends recoating annually:
http://www.yachtpaint.com/Literature...rine-guide.pdf
It's 5 o'clock somewhere:
bljones is offline
post #23 of 47 Old 10-06-2013
bljones's Avatar
Originally Posted by StormBay View Post
Maintenance aside, I honestly can not see that much difference between an amateur application of Cetol natural teak and an amateur application varnish even if the varnish is applied correctly. It just looks like a different band of varnish. No one at our marina that has seen our teak has guessed it was Cetol, and I put it on with the $0.75 brushes from home depot. Ours has been roasting away in the florida sun for 2 years and is showing no sings of quitting any time soon. We have acres of teak; it takes a full quart and a good half of a day for one coat. Its hard to see from the crappy cellphone pic but all of the ribboning shimmers in the light, Cetol does not obscure it al all.
Looks great.
How many coats?
bljones is offline
post #24 of 47 Old 10-06-2013
Jnoiur Mebemr
StormBay's Avatar
Originally Posted by bljones View Post
Looks great.
How many coats?
3 initial coats of natural teak followed by 1 maintenance coat of gloss every 7 to 10 months ( I aim for every 6 months as the sun down hear is brutal, but I haven't been on schedule yet) so 6 coats total in 2 years. The gloss is what really makes it pop compared to the semi matt finish of the plain natural teak.
Yu & Frank
StormBay is offline
post #25 of 47 Old 10-06-2013
Jnoiur Mebemr
StormBay's Avatar
Originally Posted by Minnewaska View Post
that's why I use Bristol Finish elsewhere. Cetol got hard and brittle and flakey and horrible. I swear I still find cetol dust in little nooks and crannies and I've had it fully removed for three years.
I also think bristol finish looks great and it should last a long time if done right, however don't expect it to come off any easer than Cetol if you ever have to refinish. removing-bristol-finish-from-teak-
Yu & Frank
StormBay is offline
post #26 of 47 Old 10-06-2013
Jnoiur Mebemr
StormBay's Avatar
Thanks! The natural teak is defiantly a better color compared to the older formulas.
Yu & Frank
StormBay is offline
post #27 of 47 Old 10-06-2013
Yup, stripping brightwork isn't fun. However, I find Bristol Finish will knock down with 60 grit and then finished with 100. If you want to try to remove a coating that is nuclear proof, try to sand Interlux Perfection Plus. Hard as nails. This two part coating is incredibly hard, but is also so toxic when applied, you may not live long enough to need to remove it.
That link tells a story of it failing. Having tons of experience with this, I will attest that any coating failure is always pilot error. I've sworn it wasn't me at times, until I finally figure out what I was doing wrong.
StormBay likes this.
Jeanneau 54DS
Minnewaska is offline
post #28 of 47 Old 10-06-2013
bljones's Avatar
Bristol finish doesn't like sharp corners or edges.
bljones is offline
post #29 of 47 Old 10-06-2013
Nothing likes an edge that water might get under. Its the number 1 cause of brightwork failure. I can't say I've notice BF any tougher than any other finish on sharp corners. None are great.
Jeanneau 54DS
post #30 of 47 Old 10-06-2013
The only threads more entertaining than varnish are about anchors.
I will not claim one is better than the other... they have different merits; choose your medicine. Varnish (generally) requires more coats, sanding between coats, is finicky to apply and needs more frequent attention... but it does look better. Cetol takes less work (no sanding between coats is BIG), is more forgiving to apply and generally more durable but does not match varnish for lustre. [I cite several Practical Sailor studies for claims that Cetol is more durable.]
Having used varnish on a previous boat, I do believe it is a fair statement that Cetol may be an aesthetic compromise but takes WAYYY less time to apply and maintain.
hriehl1 is offline
Tags
cetol
interlux epoxycop.. groundhog Gear & Maintenance 1 05-29-2009 03:34 AM
Sikkens-Cetol Marine Natural Teak? BigMoe Gear & Maintenance 12 05-05-2009 10:40 AM
sikkens cetol question gwp Gear & Maintenance 4 12-21-2003 05:02 PM
Cetol vs cetol light Lastmango69 Gear & Maintenance 2 07-22-2003 05:12 PM
Sikkens marine varnish obiec Gear & Maintenance 3 05-13-2003 03:55 PM
