Interlux Schooner vs. Sikkens Cetol - Page 5 - SailNet Community
 14Likes
post #41 of 47 Old 10-09-2013
Re: Interlux Schooner vs. Sikkens Cetol
Originally Posted by jimgo View Post
Um, you forgot to add the discussion about rebedding - Since I'm going to be redoing the finish on everything, I'm also going to rebed the brightwork. I'm planing on use silicone caulk because everybody says not to buy "marine" versions of stuff since it's just overpriced BS. Although, I've heard good things about something called 5200, and might use that instead.......
Jim, what exactly are you rebedding? I would not think of 5200 as caulk, but as permanent, very permanent, glue. You will likely have to break the item to get it off again.
I've caulked so much stuff over the years, that I'm probably personally responsible for at least one 3M executive bonus payout. However, it doesn't last as long as more modern solutions. Particularly, for hardware that is stressed, like handholds. I'm a convert to butyl tape.
Re-Bedding Deck Hardware Photo Gallery by Compass Marine at pbase.com
Jeanneau 54DS
Minnewaska is offline
post #42 of 47 Old 10-09-2013
Asleep at the wheel
jimgo's Avatar
Minne, I was kidding. I was going along with BLJones' comment about the most interesting thread. I'm a fan of butyl (ordered from Main Sail), though I've also use Life Seal for some projects, too. I know to essentially stay away from 5200 (a bit of an exaggeration) for most of my projects.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #43 of 47 Old 10-09-2013
Minne, I was kidding. I was going along with BLJones' comment about the most interesting thread.......
Right over my head. Sorry.
Hey, it was before 5am and you didn't quote the post you were replying to.
jimgo likes this.
Jeanneau 54DS
post #44 of 47 Old 10-09-2013
This my friends is Interlux Schooner 92, a Phenolic varnish, the varnish traditionally used for the finest bright work. Click on it for a better view.
Dick
Flybyknight is offline
post #45 of 47 Old 10-09-2013
Epiphanes varnish on a cockpit table leaf. 10 coats. Nothing like it.
Jeanneau 54DS
post #46 of 47 Old 10-09-2013
Asleep at the wheel
jimgo's Avatar
Minne, next time you take a picture of a nearly mirror-smooth surface, could you get a cuter model to pose in the pic?
Minnewaska likes this.
- Jim
1980 Allmand 31
1975 Albacore 15
jimgo is offline
post #47 of 47 Old 10-10-2013
Once known as Hartley18
Classic30's Avatar
Dock
I'd agree with that.. although, having used both International's "Schooner Tropical" (presumably the same as the Interlux stuff), Epiphanes and Uroxsys (in increasing order of cost!) I'd have to say that the more expensive the product the better it is. Epiphanes is really very good, but the Uroxsys stuff (if you can get it) is easier to use, longer lasting and at least as nice to look at.
..but, now, being tired of the poor shelf-life of varnishes in general and no longer being willing to watch $$$ worth of varnish go off in the tin, I now just use the cheap stuff and go sailing.
Classic30 is offline
Tags
cetol
interlux epoxycop.. groundhog Gear & Maintenance 1 05-29-2009 02:34 AM
Sikkens-Cetol Marine Natural Teak? BigMoe Gear & Maintenance 12 05-05-2009 09:40 AM
sikkens cetol question gwp Gear & Maintenance 4 12-21-2003 04:02 PM
Cetol vs cetol light Lastmango69 Gear & Maintenance 2 07-22-2003 04:12 PM
Sikkens marine varnish obiec Gear & Maintenance 3 05-13-2003 02:55 PM
