To store halyards or leave on mast? - Page 2 - SailNet Community
 3Likes
post #11 of 18 Old 10-06-2013
Gary M's Avatar
Re: To store halyards or leave on mast?
I take all of my halyards and all running rigging home every fall and wash it all in warm water and soap then and I use fabric softener on it. You will be surprised at how dirty your water gets and how much softer they all are when dry.
I just duct tape about 4 inches of small messenger line to my halyards and pull them through. Of course I take my mast down every year so if one lets go it is not a big deal to fish it back though.
Don't use a natural fibre like sisal as it will rot by spring and give you major headache. Don't ask how I know this
Gary M is offline
post #12 of 18 Old 10-06-2013
Learning the HARD way...
eherlihy's Avatar
Hi csharp56,
I also live in MA, but keep my boat in RI. Every year I attach one messenger line to all of my halyards, and run them up the mast. In the spring, I carefully pull them back down.
The advantage is that I am preventing UV damage on all but the ends of the line. If necessary, I can splice a new eye in the halyards.
Regarding the roller furling line; I remove it and store it with the jib sheets in the V berth.
Welcome to SailNut!
eherlihy is offline
post #13 of 18 Old 10-07-2013
Sabreman's Avatar
After a number of years of weathering, I flip the halyards end for end, putting a new eye on the old tail. Since half our halyards are always inside the mast, this exposes shiny new line. The combination of removing lines each winter and flipping them at half life, gives me at least 10 years out of a halyard.
To me, old, moldy lines are depressing as are rat's nest piles of uncoiled lines lying on deck. There is an old saying that "ye can tell the measure of a sailor by the way they keep their lines" or something salty like that. I think that it's quite true.
Sabre 38 "Victoria"
Sabreman is offline
post #14 of 18 Old 10-16-2013
I never used to pull the running rigging. Then I replaced all of the lines on my catboat three years ago and realized just how expensive those little buggers are. Well over $1k for Endura 12 lines on my 22. It is a cat, with 8 lines for that one sail, but still, significant. I now clean and store the lines at home, which has the side benefit of keeping them looking much fresher compared to the grey weathered look of older lines.
Mike sullivan
1985 Marshall 22 catboat
mbsl98 is offline
post #15 of 18 Old 10-16-2013
pdqaltair's Avatar
Perhaps it depends on what your time is worth to you as well. Personally, I can't see it. If there is chafe, I end-for-end them, but generally there is not; if there is, something is wrong. They last 10+ years anyhow; by that time I'll be re-rigging something.
Sail Delmarva: Seven Sins I Will NOT Commit This Spring
Sail Delmarva: Fall Maintance and OCD
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #16 of 18 Old 10-16-2013
Over Hill Sailing Club
smurphny's Avatar
I always remove all the halyards when putting the boat up for any amount of time. UV is tough on expensive line. I just buy some cheap 1/4" nylon or poly, attach the bitter end of the halyard and run them up through the sheaves/blocks and tie them off nice and tight. Have never had a problem doing this. I need to get some dedicated small line and hide it somewhere because it always seems to get used for something else and is not there when needed. Presently, my spinnaker halyard is still up, rotting in the sun because I could not find another piece of small line to do this last halyard before buttoning the boat up. Grrrrr.
smurphny is offline
post #17 of 18 Old 10-16-2013
Omatako's Avatar
We sail all the way through winter which would be tough without running rigging . . . .
Arthur C. Clarke
Omatako is offline
post #18 of 18 Old 10-17-2013
I don't discuss my member
zz4gta's Avatar
Strip the boat during the winter. Run messenger lines. A good finished halyard can easily run you $400+ for a decent sized boat. For a basic 3 halyard setup, that's 1200+.
Merit 25 # 764 "Audrey"
zz4gta is offline
Leave mast up or take down for winter rundugrun General Discussion (sailing related) 13 10-29-2011 03:23 PM
Mast Steps and Halyards casey1999 Gear & Maintenance 5 06-02-2011 02:42 PM
The Mast, for new Rigging, off or leave up? Jasper Windvane General Discussion (sailing related) 11 11-22-2009 07:44 AM
winter store-mast up or down? victorias Hunter 10 05-03-2009 08:42 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
