Measuring Tool - Page 3 - SailNet Community
 3Likes
post #21 of 26 Old 10-07-2013
TQA
Bombay Explorer 44
TQA's Avatar
Re: Measuring Tool
A dial gauge while useful will only tell you the degree of ovality of the cylinder and a rough idea of the wear comparing the very top part with the worn part.
Pros will use an inside mike to measure the actual inside dia.
TQA is offline
post #22 of 26 Old 10-07-2013
tommays's Avatar
Re: Measuring Tool
Well
I have honed a thing or a 1000 over the decades and we always have ring gauges to set the bore gauge (dial gauge) or there not really of much use
The three point internal micrometers are pretty pricy and have very limited ranges
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #23 of 26 Old 10-07-2013
no longer reading SailNet
Alex W's Avatar
Re: Measuring Tool
Originally Posted by Frogwatch View Post
Would the "inside jaws" of a set of calipers work? Everybody should have a pair of calipers. How else you gonna measure really accurate stuff. Unfortunately, modern calipers are all in units of mm or inches and not RCH.
Besides not going deep the accuracy on a set of calipers isn't that great. Repeated measurements, especially using the inside jaws, are often off by a couple thou (or tens of millimeters) from each other. A micrometer or bore gauge is more accurate.
Alex W is offline
post #24 of 26 Old 10-07-2013
Missingyou's Avatar
Re: Measuring Tool
The picture is of my inside micrometers, something I've barely ever used. When we did bore work we used a dial bore gauge that was referenced to a known I.D. It was much quicker to check the bore at different depths with the dial bore gauge. When honing the key is to create a nice straight bore, it's very easy for it to become fat in the middle if you dwell too long with a hone. Frankly a proper honing machine is the best way.
Missingyou is offline
post #25 of 26 Old 10-07-2013
Omatako's Avatar
Re: Measuring Tool
Originally Posted by wind_magic View Post
They do make calibration tools for this though, I just found that out yesterday. It is called a "master ring gage" which is a circle with a known size that comes in different levels of accuracy.
Well, I have been in engine repairs one way or another for four decades and have to acknowledge never having seen those before. You learn something new every day.
I would venture to suggest though that the expansion in a ring like that would well exceed that of a straight distance piece for the same temperature change. Which is probably why it's marked with the temperature at which it is accurate.
I have no scientific reason for saying that - I just remember heating ring gears to expand them before shrinking them onto a flywheel. It doesn't take a lot of heat to make the ring gear significantly over-size.
I wonder if these rings come with a "deviation chart".
Arthur C. Clarke
Omatako is offline
post #26 of 26 Old 10-08-2013
Re: Measuring Tool
You are absolutely right, a bore gage with a ring gage to calibrate is the ultimate (unless you have a CMM on board). I will allow you to take several calibrated measurements quickly and will take operator "feel" out of the equation for the most part. However, if you want to get measurements within a few tenths in the most economical fashion for a one off job, a telescoping gage with an outside mic is the way to go.
A dial gage can be very accurate (every bore gage uses one) and is great to measure your shaft run out, but by itself is of no use for this job.
dillybar is offline
Measuring a foresail Gregrosine General Discussion (sailing related) 4 07-10-2013 08:46 PM
Measuring stainless dimension. GMC Gear & Maintenance 7 06-12-2012 01:12 PM
Measuring Battery Voltage ccriders Electrical Systems 6 11-13-2010 07:41 PM
Re: FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Run NewsReader Mass Bay Sailors 0 03-04-2007 12:15 PM
FYI - Freeware Tide Tool V2.2 is now in Tide Tool Beta 2.3 (Runs on NewsReader Mass Bay Sailors 0 03-03-2007 05:15 PM
