How to repair "cockpit cubbies"? - SailNet Community
 7Likes
  • 2 Post By SlowButSteady
  • 5 Post By Alex W
post #1 of 10 Old 10-05-2013 Thread Starter
My boat has little cubbies (about 6" high and 18" wide) along each side of the cockpit. Handy for storing jib sheets and other odds and ends. Problem is that the cubby enclosures are formed from very thin FRP, which is cracked in a few spots, and even worse, the aft ends were broken out by a PO in order to better access the winch bolts. As a result, one cubby leaks pretty bad when it rains. Aside from the leaking, they don't drain very well, so they end up full of mold and gook.
So I'd like to close them off. I'm thinking about cutting some starboard panels of the appropriate size and gluing them in place, or maybe using some sort of mechanical fasteners so that I can remove them later (perhaps to access the winch fasteners).
Any suggestions, or similar experiences?
1981 Spirit 28 "Bonnie Lass"
Bremerton, Washington
Rusty123 is online now
post #2 of 10 Old 10-06-2013
Senior Slacker
SlowButSteady's Avatar
Re: How to repair "cockpit cubbies"?
I would repair the holes/cracks with some epoxy and fiberglass. Maybe add a layer or two over the entire surface to beef it up a bit. Then drill a drain hole or two in the bottom of each box, add a little flush "thru-hull" fitting to each, and run a bit of tubing to cockpit drain (or maybe even to the cockpit itself) to keep the water from getting your back wet. It looks like they have drains, but from your post they obviously aren't doing the job.
But, IMHO, little coaming boxes like that are way too handy to glass over.
jameswilson29 and jimgo like this.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #3 of 10 Old 10-06-2013
Eliminating storage on a sailboat is not a good idea. It would even de-value the boat. Unfortunately, you're going to have to figure out the best way to repair it.
Jeanneau 54DS
Minnewaska is offline
post #4 of 10 Old 10-06-2013
14432's Avatar
It looks like you have decent access to the inside behind the damage. I would repair by first making a backing piece with 1-2 layers of fiberglass. Find a wash pan or something plastic that pretty closely matches the curve of the box. Wax the tub and wet some glass mat or cloth with epoxy resin, place it on the outside of the tub and let cure. Do not use too many layers or it will be too stiff. After the piece cures you can trim with scissors to the right size. Epoxy the piece to the back of the box then you can complete the cosmetic repair from the outside.
You may need to do the top most area separately but that pre-fab piece will cover most of the opening.
14432 is offline
post #5 of 10 Old 10-06-2013
no longer reading SailNet
Alex W's Avatar
The easiest solution would be to buy similar sized plastic ones, remove the existing FRP ones, and then open up the hole to fit the new plastic one.
Here is one example:
Cockpit Storage Pocket | SSI Custom Plastics
Something very similar to those is used on my Pearson and they work very well.
Faster, sailak, Minnewaska and 2 others like this.
Alex W is offline
post #6 of 10 Old 10-06-2013
Home run. Game over. Excellent suggestion.
Jeanneau 54DS
post #7 of 10 Old 10-06-2013 Thread Starter
Those plastic enclosures are awesome! I was planning to post more questions about fiberglass techniques, but these make that moot. I see they also sell drink holders and speaker enclosures, other items I've considered fabricating. Thanks!
post #8 of 10 Old 10-06-2013
Great input, Alex!!
Faster is online now
post #9 of 10 Old 10-06-2013
14432's Avatar
Boom
14432 is offline
post #10 of 10 Old 10-06-2013
Senior Slacker
Doh! I should have thought of that; especially since I have been thinking of installing a couple of similar pre-made boxes in my boat.
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Tank Leaks / Repair --- "Microseal" --anyone hear of it? RonRelyea Gear & Maintenance 1 06-15-2013 08:21 PM
Blister repair without drying the hull - EpoxyUSA "Bliscoat" system afrinus Gear & Maintenance 5 04-02-2013 08:40 AM
Does anyone have an Edson "poly" cockpit table? josrulz Gear & Maintenance 5 02-28-2012 11:36 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
