Reefing trouble - Page 2 - SailNet Community
post #11 of 20 Old 10-06-2013 Thread Starter
Re: Reefing trouble
Yes, that second picture is old but everything has been put together and adjusted.
What I did was pull what I think is called the balance block out of the back of the boom. I then took a life line off(that's all I had that was stiff enough), connect the line and fed it through the front of the boom, and came out the back. Then I routed it back through the balance block, back into the boom, and fed it all back out through the front. I then put the balance block back into the boom, and tried to pull it back to about where I thought it was. This is probably where it got tangled.
There is an out haul, topping lift(which I will probably get rid of) and the second reef that is also going through the boom... oh and a birds nest
skysail is offline
post #12 of 20 Old 10-07-2013
Re: Reefing trouble
Your boom looks to be the same as mine old one.
You should be able to look inside the boom and see the lines there.
Need a torch (AKA flashlight) (not to big with good light).
Look into the hole at the boom end.
Pictures of the boom end
Last edited by knuterikt; 10-07-2013 at 10:20 AM. Reason: flashlight (torch in British English)
knuterikt is offline
post #13 of 20 Old 10-07-2013
Re: Reefing trouble
Need a torch (not to big with good light).
To be clear... he means a flashlight!!
Faster is online now
post #14 of 20 Old 10-07-2013 Thread Starter
Re: Reefing trouble
Yeah, I think it's the same, I was able to see through it, and that's where I pulled the balance block out of.
skysail is offline
post #15 of 20 Old 10-07-2013
Re: Reefing trouble
Thank's
Neither British English nor US English is my native language - get a bit confused with the small differences sometimes.
A flashlight (torch in British English)
post #16 of 20 Old 10-07-2013
Re: Reefing trouble
You should be able to see if any of the lines are crossed inside.
It might be good to have a helper pulling the different lines while you are looking inside.
If you have two line reef - I doubt there are any balance blocks there.
The blocks you see are most likely to be purchase for the outhaul.
post #17 of 20 Old 10-07-2013 Thread Starter
Re: Reefing trouble
There is a balance block. I took it out by pulling the leach reef line. There's 2 separate lines for each reef. The out haul does not need a block, nor does the topping lift. Maybe I'm using incorrect terms.
skysail is offline
post #18 of 20 Old 10-07-2013
Old as Dirt!
svHyLyte's Avatar
Re: Reefing trouble
Considering that there is no winch between the attachment point of the vang at the lower portion of the mast and the goose-neck, the internal block is certainly to allow a 2:1 purchase on the out-haul which I suspect is the line exiting the underside of the boom on the outermost sheave on the port side, below the goose neck, and wrapped around the cleat on the boom. That would be the only way one could get a sufficient purchase to out-haul the foot of the sail in any wind.
The three remaining boom sheaves, fore and aft, would be for the reefing lines. With the out-haul on the port most side, the reefing lines should be attached to the boom directly below the reef cringle. While a loop around the boom secured with a bowline would be preferable, considering the stack-pak, that may not be possible unless there is a slot beneath each reef cringle for the reefing line to pass through. If not, you can tie the reefing line(s) to the bales that slide along the bottom of the boom, sliding each directly beneath the reef cringles. Then pass the reefing line up, outside the stack-pak or through the slot if one is provided, through the reef cringle and then aft, down and around the boom sheave and then forward up and over the matching sheave at the goose neck and down through the exit slot on the under side of the boom.
To pull the reefing lines, one can position messenger lines with a metal tape measure by extending it through the boom from the goose neck end to the outboard end. The tape will be stiff enough that it should slide through the boom without difficulty (I've done it on my boom which is over 17' long so on yours, at about 12' it should be pretty easy.) If you feel you only need two reefs, use the starboard most set of sheaves on the boom for your first reef and the next inboard set for your second. Again, the reefing lines should go from the boom, up to the reefing cringle (on the port side of the sail), through the cringle and down on the starboard side of the sail to the outboard sheaves and back through the boom to the inboard sheaves. There they pass over the tops of the sheaves and down through the bottom of the boom where there should be small locking cams that will hold the lines in place once you release the tension on them as you are reefing.
Do not discard your topping lift unless your solid vang will support the boom and associated rigging while you reef. If not, you'll need the topping lift so that all of your effort/energy goes into down- and out-hauling the sail itself and not also supporting the boom and it's gear. When reefing, ensure you down-haul and secure the associated reef cringle at the luff before you start working on the leach cringle. Then you can tighten the luff, ease the topping lift and be on your way.
svHyLyte is offline
post #19 of 20 Old 10-07-2013
Re: Reefing trouble
Possibly incorrect terms.
By two line reef we are referring to a setup with two reef lines going back to the cockpit for each reef - one for the luff/tack reef and one for the leach/clew reef.
There are two different setups for single line reef
One type have a balance block inside the boom witch connects both reef lines for the reef so only one line is lead to the cockpit.
The other type have one continuous reefing line that starts at the boom up through the reef cringle at the leach through the sheave at boom end forward up through the boom at the goose neck through the reef block a the luff down and back the winch.
Here is a picture from my boat (two line reef)
The white&green line is one of the luff/tack reef lines
The white&red you can see at top of the inboard boom end going down is one of the leach/clew reef lines.
The other end of the boom only reef 1&2 attached to the sail (that's why you donŠ't see the white&red reef line
post #20 of 20 Old 10-07-2013 Thread Starter
Re: Reefing trouble
So what I am getting out of this is that I have single reef line with a balance block. I only use one line to reef from the cockpit.
One line for reef number 1 which is on the starboard side of the cockpit, and one line for reef number 2 on the port side.
My boom vang holds up the whole boom like the topping lift. I raised it up a little, dropped the mainsail, and pulled reef number 1 from the cockpit. This is where I pulled out the line, where it was not tied properly to the luff. So I then resorted to reef number 2, raised the sail, and all went well.
I really appreciate everyones help. Thank you!
skysail is offline
HMS Bounty in trouble... jimjazzdad Vessels Lost, Missing, or in Danger 1949 03-03-2013 10:50 AM
Reefing without reefing points Rup Seamanship & Navigation 29 12-03-2009 04:19 PM
Trouble with attachments danjarch Announcements and Suggestions Box 8 08-29-2007 11:18 PM
MD-11C RPM,s Trouble flydude3 Gear & Maintenance 0 05-22-2004 04:51 AM
