Raw water strainer elevation. - SailNet Community
post #1 of 4 Old 10-09-2013 Thread Starter
Missingyou's Avatar
Does anyone know of a guideline for mounting a raw water strainer, specifically height from the through hull, water line, engine, etc. I have a new boat and the Generator is having problems picking up raw water. The strainer seems very high and I wonder if this is the problem. It's access is also very challenging because of AC ducting. I'm thinking about moving it into the rear lazerette, closer to the through hull.
Missingyou is offline
post #2 of 4 Old 10-12-2013
Re: Raw water strainer elevation.
Strainer low and uphill hose to water pump to prevent airlocking would be my guess. Non collapsing hose , adequate dia of course.
Capt Len is offline
post #3 of 4 Old 10-13-2013
I prefer the intake side of the strainer to be at least above the water line. Any lower, and when you open the strainer to clean it out you will have water coming in constantly.
Greg
Stumble is offline
post #4 of 4 Old 10-13-2013
Closing the valve solves that problem and allows testing to see if water can flow.without pulling hoses (plastic bag or head of cod fish..Had both)
Capt Len is offline
Sea Water Strainer joub Gear & Maintenance 14 10-22-2015 04:35 PM
Raw water strainer smurphny Diesel 18 08-13-2013 03:49 PM
Raw Water Strainer SloopDogg Gear & Maintenance 2 05-18-2012 08:18 AM
Raw-water strainer maboyer Gear & Maintenance 6 12-05-2007 01:34 PM
Raw Water Strainer Jotun Gear & Maintenance 27 03-30-2007 10:33 PM
