How can I identify the waterline from inside? - Page 2 - SailNet Community
 7Likes
post #11 of 17 Old 10-11-2013
MarkofSeaLife's Avatar
Dock
Re: How can I identify the waterline from inside?
Originally Posted by Barquito View Post
So, I take it that my idea of: drilling a series of holes from the top down until water starts streaming in... is not going to win?
Opps! I screwed up your advice and started from the bilge.
Sea Life
Notes on a Circumnavigation:
MarkofSeaLife is offline
post #12 of 17 Old 10-11-2013
Maybe the waterline changes a bit when heeled or the wife is standing on the bow?
Capt Len is offline
post #13 of 17 Old 10-11-2013
MikeGuyver
look down the galley sink & measure up to the drain board .
MikeGuyver is offline
post #14 of 17 Old 10-11-2013
baDumbumbum
bobmcgov's Avatar
We plan to mark ours on the inside after painting; when the boat's on the hard, you can use strong magnets to trace around the bootstripe. Need a helper on the inside to trail a pencil & hop over bulkheads.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #15 of 17 Old 10-11-2013
Tartan 27' owner
CalebD's Avatar
I like the strong magnet idea Bob.
If the weather is just right and there are small wavelets hitting the side of your hull you can put your ear to the FRP and hear where the wave sound is loudest.
Faster's thru hull hose idea is easier though.
In extreme desperation you could open a through hull and flood the cabin up to the water line (you'll know when you see it). Then drain it all out and carefully trace the high water line and clean up your boat. ;-!)
Everybody has one:
CalebD is offline
post #16 of 17 Old 10-11-2013
rugosa's Avatar
In the factory we used bright light for quality control. If you are looking in a localized area of the hull (near the head?) a strong flashlight in a ziploc against the hull could work.
rugosa is offline
post #17 of 17 Old 10-12-2013
Shut the seacock. Disconnect the hose from head. hold hose up . Open valve. lower hose till water flows. Voila!
mitiempo likes this.
Capt Len is offline
Low waterline jamesjle Gear & Maintenance 2 07-28-2013 02:52 AM
How do you measure the waterline boatingcruising General Discussion (sailing related) 12 07-27-2012 07:11 PM
Sealant for below the waterline... sailhog Gear & Maintenance 4 03-01-2010 06:41 PM
Waterline Ronbye Gear & Maintenance 7 05-16-2006 07:19 AM
LP below waterline? birdboat Gear & Maintenance 1 01-21-2003 03:22 PM
