-   -   How can I identify the waterline from inside? (http://www.sailnet.com/forums/gear-maintenance/104603-how-can-i-identify-waterline-inside.html)
ericb760 10-10-2013 05:40 PM
Is there an easy or simple way to correctly identify the waterline while inside the boat? I'm contemplating an overhaul of the head system and need to install an airgap above the waterline but space is tight...
minnow1193 10-10-2013 05:54 PM
I would think if you are in still water, you could measure down from the deck joint outside, then make the same measurement inside (assuming you can locate the joint from inside. Or use any other reference point.
Seaduction 10-10-2013 05:59 PM
Re: How can I identify the waterline from inside?
Attach a "water level" to an underwater thru hull fitting.
erps 10-10-2013 07:02 PM
I would try a hand held infra red thermometer and shine it on the inside of the hull to see if can find the boundary between the water temperature and the air temperature.
Faster 10-10-2013 07:26 PM
A long piece of soft transparent tubing (tygon) temporarily attached to any open through hull with the end carefully held above the waterline would flood to the same height... should work!
mad_machine 10-10-2013 08:16 PM
not only that.. but as long as the majority of the hose were kept beneath the waterline.. you could use it anywhere aboard as water will -always- seek it's own level
ericb760 10-10-2013 10:32 PM
I think post #2 will get me close enough, I was just wondering if there was some old mariners trick to it. Thanks for all the suggestions...
minnow1193 10-10-2013 11:42 PM
I win! :D
Seaduction 10-11-2013 06:57 AM
Correct. That is a water level.:)
Barquito 10-11-2013 03:08 PM
So, I take it that my idea of: drilling a series of holes from the top down until water starts streaming in... is not going to win? :)
