Alodine - SailNet Community
post #1 of 15 Old 10-11-2013 Thread Starter
JSailer's Avatar
Question Alodine
Hello,
Does anyone have any experience with Alodine 1201?
I need to know if a piece of aluminum tubing underwater would be protected enough from corrosion with Alodine treatment.
I would like to have it anodized but I cannot find anyone in my area who does that so I am looking into Alodine as another option.
Thanks.
O'Day 30 - Stuart, FL
Oceanis 411 - South of France
JSailer is offline
post #2 of 15 Old 10-11-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
Re: Alodine
I have used Alodine 1201 in the military on aircraft, and on my boat. I do NOT think it would be useful for underwater application. Just not enough protection.
What are you trying to make?
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #3 of 15 Old 10-11-2013
Irunbird's Avatar
Re: Alodine
Agreed- not enough protection for below waterline. I've immersed countless helicopter and jet parts in the stuff prior to painting with a very toxic (and no longer in use) primer- polyamide or zinc chromate as an anti-corrosive prior to finish coating in either a lacquer for interior parts or two-part polyurethane for exterior surfaces. One option you may consider is coating with West System epoxy, then painting if necessary. Here's a table summarizing the technique for that process- WEST SYSTEM - Projects - Effects of surface treatments on adhesion to metals
Irunbird is offline
post #4 of 15 Old 10-11-2013 Thread Starter
JSailer's Avatar
Re: Alodine
Greg
Thank you for the replies.
I need to replace the tube that the centerboard cable goes through.
It is about 8 inches into the keel and goes through the cabin up to the deck.
It's 1.5 in OD with 1/8 wall.
About 3 feet would be under water (by that, I mean saltwater will be inside the tube at all time up to the waterline).
JSailer is offline
post #5 of 15 Old 10-11-2013
Markwesti's Avatar
Re: Alodine
Hi JSailer , why not use SS tube and make sure its seamless . I had a O'Day 23 once . O'Day makes a good boat .
Markwesti is offline
post #6 of 15 Old 10-11-2013
Delezynski's Avatar
Re: Alodine
JSailer,
Have you considered some other material, other than a metal tube?
I have never had a swing keel so I am on shaky ground, but I might think about something like a reinforced exhaust hose?????? Just thinking outside the box.
Greg
Home page -
Youtube page -
post #7 of 15 Old 10-11-2013
Tartan 27' owner
CalebD's Avatar
Re: Alodine
The C/B pennant on my Tartan 27' runs through some sort of black hose to the C/B trunk. There is salt water in the bottom of it only.
Everybody has one:
CalebD is offline
post #8 of 15 Old 10-11-2013
Re: Alodine
In my opinion, the best metal would be bronze. But maybe some kind of plastic or polymer would work? Here is what McMasterCarr can do :
McMaster-Carr
How about PTFE-filled delrin?
What was the old tube made of?
MarkSF is offline
post #9 of 15 Old 10-11-2013 Thread Starter
JSailer's Avatar
Re: Alodine
The original tube is aluminum and lasted 35 years and is just now starting to go...
I had been advised to stay with Aluminum.
I considered SS but was told I might have bigger corrosion concerns with it. I am not a metal expert (obviously) but i have seen SS fittings or parts corrode underwater in short period of time before so I am not convinced SS will be the answer but I am still open to that idea.
My concern is the area right by the waterline sloshing in and out of water/air.
Also, the tube has to be rigid and solid because it goes through the cabin table and I offers some stability, and it also offers some support to the cabin top.
JSailer is offline
post #10 of 15 Old 10-11-2013 Thread Starter
JSailer's Avatar
Re: Alodine
This boat does not have a trunk in the cabin.
The tube goea down to the top of the keel just below the cabin sole which is about 2 to 3 feet below the waterline.
JSailer is offline
