Boat Wired w/ Fiber Optics - SailNet Community
 1Likes
  • 1 Post By Faster
post #1 of 10 Old 10-11-2013 Thread Starter
I know this may sound a little off the wall....
I was watching a PBS special on Hurricane Sandy. The power company was being interviewed (ConEd I think) and they stated all their copper cable was rendered useless by the ocean surge. To combat it they were rewiring with fiber optic cable which was impervious to salt water. It set my mind to thinking.
How much more would it cost to do the same in new build sailboats? And, if more expensive up front, might the lack of maintenance and stability down the road overcome the upfront costs?
Just a thought.
ps-love this site! So much to learn
opc11 is offline
post #2 of 10 Old 10-11-2013
Re: Boat Wired w/ Fiber Optics
Fiber optics is a communication medium... not a power medium. To convert (even digital communication energy) to light - and back - takes specialized equipment.
I would expect that the 'power company' lost the ability to communicate with their substations and networks... rather than the actual power lines..
Jgbrown likes this.
Faster is offline
post #3 of 10 Old 10-11-2013 Thread Starter
thanks Faster, you're probably right.
opc11 is offline
post #4 of 10 Old 10-11-2013
rugosa's Avatar
What about this - Fiber Optic Endglow Cables
rugosa is offline
post #5 of 10 Old 10-12-2013
bblument's Avatar
Rugosa,
Let me try and rephrase what Faster wrote, correctly, above. Fiber-optic cables transmit light. The cables you linked to transmit light from a source to another location where light is desired. They can not transmit electrical energy; only light energy. Communications companies use them to transmit data by translating the data into fluctuations (modulations) in the light being transmitted. That's why you need a modem (MOdulator/DEModulator) at the each end of the cable.
Electrical power, or electricity, is a flow of electrons. They can't pass along fiber-optic cables, as they are not electrically conductive. Similarly, light can't be transmitted by standard copper wire.
I've seen fiber optic cables used to transmit light from one single source bulb hidden in the dash board of a car to many locations on the dash via optic cables. Pretty neat design; only one bulb to burn out and eventually replace, and much fewer corrosion-prone electrical connections. There's no reason you couldn't do something similar on a boat, but it'd require a pretty substantial light source and fiber cabling to do anything resembling ambient lighting. Usually, at least in my experience, fiber-optic lighting is used for very specific pin-point lighting. Of course, I haven't got much experience......
Barry
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza." - Dave Barry
bblument is offline
post #6 of 10 Old 10-12-2013
rugosa's Avatar
Originally Posted by bblument View Post
Rugosa,
Barry
I was thinking only of lighting - like one source to light all cabin lights. Could eliminate of the typical 12v incandescent bulbs, lots of wire weight, contact corrosion. Maybe create some great mood lighting at boat shows to romance the buyers of shiny new toys. No idea where to start though. Then again, LED lighting has now filled the power gap issue.
rugosa is offline
post #7 of 10 Old 10-12-2013
The OP has confused ConEdison with Verizon.
One turns out your lights and heat, the other turns out your phones, computers, and TV's.
hellosailor is offline
post #8 of 10 Old 10-12-2013
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Barry
I have a 1972 Fiat Spider with that set up from the factory. All the lights on the centre console are connected to one light by an "octopus" of fibreoptic cables... so it is not new technology, nor all that expensive
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
post #9 of 10 Old 10-13-2013
bblument's Avatar
Coincidentally, that's the car I was referring to!! I renovated two of them... a '71 and a '74. I don't have either any more, but I'd love to find another one in good shape... they're a TON of fun, and handle beautifully. I just got sick of working on them all the time...
Barry
bblument is offline
post #10 of 10 Old 10-14-2013
Large Member
My '69 Malibu has a fiber optic cable to the ash tray for illumination.
mdbee is offline
1/2/Both switch is AFD wired, but to where? WoobaGooba Electrical Systems 7 10-02-2013 07:54 PM
wireless vs wired fjcruiser Electronics 10 05-23-2013 11:52 AM
Wired Up My Mast Squidd Gear & Maintenance 4 03-20-2012 05:31 PM
Barz Optics new Floater for Newport Show barzop Gear & Maintenance 0 07-16-2011 08:24 PM
mast is wired - do I need to redo part? LookingForCruiser Gear & Maintenance 8 06-21-2009 06:33 PM
