How much deck over the cabin do I remove? - Page 4 - SailNet Community
 3Likes
post #31 of 40 Old 10-26-2013
Re: How much deck over the cabin do I remove?
Mr. Chef, your 26 has the outboard engine right? If so that really helps keep costs under control. If it just cost you a few hundred bucks to get it towed to your place, that is not much of a risk, money wise. That is a good way to get into sailing if you ask me.
This winter I will map out the spots that puff up on the deck from the freezing in the plywood core. I'm thinking of marking them with green painters tape and taking photos, then removing the tape(so it doesn't look so silly). That way in the warm weather if I choose to repair something I will know how far the worst of the water damage is.
Minnewaska, no thanks, we just -gave away- a like new, barely used piano!
YRoy is offline
post #32 of 40 Old 10-29-2013 Thread Starter
Here is a link noting condition upon arrival at my house. I already soft scrubbed the cockpit and WOW it looks amazing! Now to finish cleaning the mold out of the interior so I can check for leaksand at least work in a clean environment.
http://https://www.youtube.com/watch...w4h6LQ&index=1
Mr. Chef is offline
post #33 of 40 Old 10-29-2013
krisscross's Avatar
I'm a real hack when repairing old boats so if you like 'pretty' - stop reading right here.
I would use a pressure treated board (on the inside) as a backing for the new rail, which would have rail posts made of pressure treated wood (or teak), filling the holes on top of the cabin with a fiberglass patch. I would drill a few holes from the inside (in the low spots of delamination) to drain the core so that the freeze damage is minimal. Trying to fix 'right' an old boat like that is usually not worth the money.
Plato
krisscross is online now
post #34 of 40 Old 10-29-2013
Umm, ouch. That looks bad, really bad. The rot at the keel/hull joint may be terminal if the rot at the deck/cabin trunk line isn't. I've cleaned up really really dirty smelly boats before, but I did so knowing that they were sound hulls. I don't think I'd spend 10 minutes on this one. I'd salvage the rig, motor, and whatever I can unbolt from the hull and get rid of the rest. Sorry to be so blunt, but if you want to go sailing, there are much better ways.
Loki9 is offline
post #35 of 40 Old 10-29-2013
Has the video been taken off of youtube?
Copy pasting the url doesn't work for me... Really hoping to see how the deck looks.
Never mind, mucking around with the url got it to work!
So looking at the video, I have a few comments:
- Is the hull solid fiberglass? If it is, there would be no rot between the hull and keel, just nasty old caulking and fairing compound?
- There seems to be a long crack along the deck, maybe where the front end of the cabin wall meets it? That would affect the structural strength of the deck.
- I think krisscross's suggestion of drilling drainage holes is a good one. It could also help assess things.
- You have the same Kobalt channel lock pliers I have!
YRoy is offline
post #36 of 40 Old 10-29-2013
Dirt Free
boatpoker's Avatar
I am very familiar with Grampians and if the cabin trunk is wet around the grab rails mounts ( as per your photo of sitting water), I guarantee the entire trunk top is saturated with extensive balsa degradation (compost). Re-coring by a pro with the proper tools and experience would be at least 100hrs. labour for the inexperienced probably four times that much.
As to repairing from above or below ... have you ever tried to wall paper a ceiling ?
Resin soaked glass fiber is much heavier and not as stiff as wet paper.
You will never recoup the expense of a repair like this. As long as the bulkhead supporting the mast step and the shroud chain plate knees are sound, consider it a disposable boat, go sail it and don't waste time or money on repairs
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #37 of 40 Old 10-30-2013
boatpoker, so if it freezes, should I be able to tell where the water is in the core? Or does that take a few years to be apparent?
YRoy is offline
post #38 of 40 Old 10-30-2013
Dirt Free
boatpoker's Avatar
Kind of a difficult question to answer but neither percussive sounding nor moisture meters will work on frozen structure. get a small hammer put some masking tape on it and get a neighbour with a relatively new boat to let you tap it to see what good core sounds like. Good core will produce a solid "click" and almost no bounce back of the hammer. Wet core will give a dull thump with little bounce back and core that has rotted and separated from the FRP will give a pronounced bounce back sort of like hitting a drum skin. It does not take long to get the hang of it if you listen carefully. There is no need to hit hard, just gentle taps letting the fall of the hammer do the work.
This is one of the few areas where a moisture meter will be quite accurate so
if you can borrow one it would take all of five minutes to map out the entire trunk.
More about Moisture Meters
I can do that
- wg
post #39 of 40 Old 10-30-2013
The original link posted was a bit munged. Try this: https://www.youtube.com/watch?v=9Ky6zbsjpfg
Loki9 is offline
post #40 of 40 Old 10-30-2013
loki9, thanks, but I got it to work by twiddling the url!
Mr. Chef, what year is your boat? I think the 26 was produced till Grampian folded in the late 70's?
boatpoker, so when the water freezes in the core it won't really be visible by looking for bulges in the deck?
I've tapped here and there on the deck and found variations in several areas. It comes and goes depending on how far I am from leaks where the deck hardware is located. Some areas are just fine, others sound dull. I haven't found much that sounds like a drum.
To bad the moisture meter is a bit on the expensive side. I think I might buy one when I go looking for boat #2. Seems like a very usefull tool for older boats.
YRoy is offline
Tool to remove core to properly mount deck hardware DamonVT SailNet FAQ 6 05-29-2012 12:22 AM
Remove deck pad eyes dhays Gear & Maintenance 9 06-07-2011 10:41 PM
Cabin and Deck Layout SVArgo Pacific Seacraft 2 09-01-2010 06:24 AM
How to remove fiberglass resin from non-skid deck traumadoc Gear & Maintenance 3 08-29-2009 08:57 PM
Replace Teak Deck or remove Myblueheaven Gear & Maintenance 2 11-04-2004 06:23 AM
