Relocating Main Sheet Mount - SailNet Community
 1Likes
  • 1 Post By Stumble
post #1 of 9 Old 10-14-2013 Thread Starter
Singlehander by Default
nighthawk's Avatar
I currently have a '77 Laguna Windrose 22. The main sheet is rigged about three quarters the way down the boom and the lower end is designed to hook up at the front of the cockpit near the entrance below deck(within about 10"). I am thinking of installing a new sheet mounting point or traveler on or slightly above the transom and attaching to the rear of the mast.
Question is---Is this doable, or should I stick with the original rigging design for any specific reason? I have no idea as to what types of stresses this will put on the boom, or if any at all.
Spencer
Laguna Windrose 22 "Wind Angel"
Catalina 16
Visit my blog--
~~When you decide to become a sailor, you start with a full barrel of luck and an empty cup of experience. The trick is to fill your cup before the barrel runs dry.~~
nighthawk is offline
post #2 of 9 Old 10-14-2013
overbored's Avatar
Re: Relocating Main Sheet Mount
the laguna 22 was rigged two different ways. one is the way you have it and the other was with a block at each corner of the transom and the block at the end of the boom. the problem with a traveler is that it would have to be above the tiller or mounted on the seats in front of the tiller. the boom can handle either position without a problem. the end boom position puts the least stress on the boom.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #3 of 9 Old 10-15-2013 Thread Starter
nighthawk's Avatar
Thanks OB--
That's kind of what I figured the answer was going to be. Not sure I like the idea of adding a third block into the mix though. I have some welding skills and thought about building a bridge type mount that would allow the traveler to run over the tiller, kind of like a through-transom style tiller. Haven't worked out the details as yet since I wanted to get some more opinions on the subject before throwing a whole lot of effort into it.
Spencer
Catalina 16
Visit my blog--
post #4 of 9 Old 10-15-2013
Also on a tiller steered boat a traveler/mainsheet aft of the helm is an awkward reach. With the controls fwd of the helm, it's a natural right hand on tiller, left for sheet or vice versa depending on the tack you're on.
You could go to an aft mainsheet setup but still lead the business end forward for easy reach, but if your purpose is to open up access to the companionway that's not going to help...
Faster is offline
post #5 of 9 Old 10-15-2013
The downside to bridging the traveler over the tiller is that you won't be able to lift the tiller out of the way when at anchor. There is also a strength issue, travelers can carry significant loads, which requires pretty beefy backing plates (most of the force is pulling up), the longer this unsupported beam is, the stronger the supports have to be. It's doable, but it may be easier to just add a quick disconnect to the main sheet block to move it out of the way while not underway.
Faster likes this.
Greg
Stumble is offline
post #6 of 9 Old 10-15-2013
Originally Posted by Stumble View Post
...... but it may be easier to just add a quick disconnect to the main sheet block to move it out of the way while not underway.
This is what we've done.. it completely clears the cockpit when we're moored or at anchor, we clip the sheet to whichever is the outboard toerail. Our traveler is at the end of our rather long bridgedeck.
Faster is offline
post #7 of 9 Old 10-16-2013 Thread Starter
nighthawk's Avatar
Thanks for the feedback Stumble, but I have a question. Being new to actually having a boat large enough to anchore out overnight, I do not undestand the need to remove the tiller at anchor. I may be a little slow, but could you enlighten me please.
Spencer
Catalina 16
Visit my blog--
post #8 of 9 Old 10-16-2013
I doubt you would need to remove the tiller, but most people will lift the tiller out of the way while relaxing after getting where you are going.
Greg
Stumble is offline
The Following User Says Thank You to Stumble For This Useful Post:
nighthawk (10-17-2013)
post #9 of 9 Old 10-21-2013 Thread Starter
nighthawk's Avatar
Yeah, relaxing! I gotta look into that a little more! I hear some people actually enjoy it!
Spencer
Catalina 16
Visit my blog--
Main sheet oday 23 jayjem5 US Northeast 6 08-13-2013 10:25 PM
Main sheet slimsloslider Gear & Maintenance 8 04-13-2013 11:47 AM
relocating main sheet...just to one side? NewportNewbie General Discussion (sailing related) 6 05-25-2012 01:43 PM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 04:26 AM
O'Day 28 Main sheet arrangement FourSeasMilford Gear & Maintenance 9 03-08-2009 10:42 PM
