Replace springs on outboard lifting bracket?? - Page 2 - SailNet Community
 3Likes
post #11 of 15 Old 03-13-2014 Thread Starter
Re: Replace springs on outboard lifting bracket??
Originally Posted by christian.hess View Post
same?
Looks like the same concept.
If you look at my pics above the springs do not seem to be under any compression when the bracket is 100% raised. Remove the bolt, pop in new spring.
I am still waiting for TH Marine's reply to my online inquiry. I will call them in a week if they have not emailed back.
christian.hess likes this.
1981 Edel 665
Dock C, Lake Front Promenade
i_amcdn is offline
post #12 of 15 Old 03-13-2014
mstern's Avatar
It seems to me that in order for the springs to provide lift throughout their range of motion, they have to be under compression even when fully raised. Certainly less than when fully compressed, but still under some tension.
mstern is offline
post #13 of 15 Old 03-13-2014
christian.hess's Avatar
yeah one spring is loose when raised meaning its well spent...the other one has enough tension to not be able to move even when raised...
but I dont think its a massive amount of tension when fulloy extended, honestly my issue will be finding a stainless spring down here not installing it
cheers
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #14 of 15 Old 10-29-2014 Thread Starter
Haul out done. Motor lift bracket is removed. I will spend the winter looking for best deal on a Garelick or equal.
There were 4 bolts holding the old one. The top two I could access nuts as they were on outside in a well just in front of engine. Two lower ones were trickier. I could either see them by sticking head into locker or I could reach them with arm stuck in locker but not possible to see AND get a wrench on the nuts. The nut closest to the locker was easy to reach with fingers and socket. The far one I could just barely reach with the socket but I did get it off by feeling around. I will have to cut an access hole in the spring to attach the new bracket.
I will also add a backing plate of something as the bolts and and small washers were all that held it in place.
1981 Edel 665
i_amcdn is offline
post #15 of 15 Old 10-29-2014
redline's Avatar
When I upgraded to a 15HP Honda I added a small 4:1 block arrangement up to the stern rail. Made lifting the 104 lb (!) motor easy, even though it involved pulling the rope the entire length of the cockpit.
Sent from my iPad using Tapatalk
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
outboard bracket for 30' champlain94 Alberg 2 11-25-2016 04:34 PM
Outboard motor bracket HARDWORK Gear & Maintenance 10 04-09-2013 03:20 PM
Another Outboard bracket question... LandLocked66c Gear & Maintenance 6 07-19-2011 09:17 PM
Outboard Bracket Issue YeahJohn Gear & Maintenance 7 12-02-2010 05:03 PM
Outboard lifting is killing me! gwp Gear & Maintenance 8 06-04-2003 06:44 PM
