Embedded Chain plate maint/replacement - Page 11 - SailNet Community
 81Likes
post #101 of 185 Old 10-30-2013
Senior Moment Member
SloopJonB's Avatar
Re: Embedded Chain plate maint/replacement
Sounds more like a buggeration bar to me.
SloopJonB is offline
post #102 of 185 Old 10-30-2013
davidpm's Avatar
Originally Posted by chucklesR View Post
The only portion of the chain plates, vertical and horizontal that actually touched anything was a 1/2 inch or so at the bottom near the cored area of the hull. It was bedded in some time of light gray compound that Dremel'd away easy.
I feel like a dog with a bone here. I'm trying to get a good mental picture of exactly what it looks like.
I operate under the assumption that whatever is done was done for a reason. The reason may be misguided, maybe wrong, maybe stupid but a reason nonetheless.
So are you telling me that the only the bottom half or less of the bottom horizontal bar was set in some sort of putty?
That would mean the the balance of the horizontal members were floating what like 1/4 to a 3/8 off the hull.?
This actually makes a lot of sense. From a fabrication point of view to make this christmas tree arrangement and have all the horizontal members lay tight to the hull would be very time consuming.
This also explains the bastard bar. It is welded on at an easily referenced point so the whole unit is shoved in from below until the bastard bar bottoms out and the bottom edge of the bottom horizontal member is puttied to the hull and you have your chain plate in positioned. Now just have the junior guy come after you and slap some glass over the whole thing and you are done.
So while the whole thing is evil from a repair point of view it makes sense from a build it quick point of view.
Not unlike hull liners on most production boats. Really stinks when you want to move deck hardware or fix wiring but saves lots of time in building the boat.
Do you think my scenario is plausible?
As to why the bastard bar was so thoroughly buried I've got this vision of junior being told to cover the chain plates so he figured he would really cover them. May not have been an engineering decision.
christian.hess likes this.
davidpm is offline
post #103 of 185 Old 10-30-2013
christian.hess's Avatar
sounds like a stopper to me...good post above!
christian.hess is offline
post #104 of 185 Old 10-30-2013
SloopJonB's Avatar
I think you've got it.
You've definitely got it.
post #105 of 185 Old 10-30-2013
davidpm's Avatar
At some point I will grind out the primary (pictured) spot of gel coat from the outside in until I run out of crack. I've not removed the plate over it yet - I'm a little leery of taking two plates off on one side quite yet - I've got a 1 mile trip and a haul out yet before they drop the mast.
I've got this video thing running in my head and I just can't picture a reason for that crack.
You said on a another CP you cut into it and a lot of water ran out.
Maybe on the CP you took apart their was water n their and if froze and cracked the hull then leaked out someplace.
The stainless, one would think would show some signs of being wet for a long time.
Oh I think I read that you didn't open out the one with the crack over it. So when you do we will learn something else.
I hope at least one chainplate is near failure.
davidpm is offline
post #106 of 185 Old 10-30-2013
davidpm's Avatar
As far a putting it back together goes I'm still seeing it going back together the same way it was put together with the following small tweaks,
1. The bastard bar is only their as a stopper and is not glued or glassed, doesn't need it.
2. The chain plate vertical is screwed to the horizontal pieces. The horizontal pieces are tapped so no nut is necessary.
3. The glassing of the horizontal pieces is done to leave a chainplate width area clear in the middle.
The only extra work is the drilling and tapping a few screws.
You put it together as a christmas tree and stick it in their and glass it in place.
Now any time you want to pull the chain plate just undo the exposed screws and drop it out. Should take about 10 minutes to pull a plate.
Adjust the width of the horizontals and the number and size of the screws to make sure it is a strong as a weld.
I know some folks have recommended putting in a knee and lots of boats have them but in my imagination I see disadvantages.
1. It is probably more work to do the knee.
2. It may introduce a hard spot on the hull.
3. You will have less flexibility on the cabinetry.
4. You will have some angles to work out if you change the plane of the chainplate
5. You may have to change something on the toe rail.
I'm just paranoid about changing too much on a boat that has done so well for so many years.
One it is always more work than expected due to reengineering.
Two I might not think of something.
davidpm is offline
post #107 of 185 Old 10-31-2013
Chastened
Ajax_MD's Avatar
I'm stunned at the amount of water that Chuck says comes out of these pockets.
Just...wow.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #108 of 185 Old 11-01-2013 Thread Starter
chucklesR's Avatar
Exactly.
The implausible part is how the heck that held against the 1000's of pounds of pull.
Fiberglass and poly-resin does not stick to stainless well at all. I did not have to grind it off, I simply pried it off (rather easily actually).
The process to remove a plate was to cut around it, then pop off the glass, then cut through the stainless (simply to make it a manageable size).
I'm going to try and take the next plate out as a single piece.
Unfortunately that is on hold until the spar is dropped because I'd rather drop it with a plan than have it decide to just drop. I'm too chicken to take two shrouds off.
chucklesR is offline
post #109 of 185 Old 11-01-2013 Thread Starter
chucklesR's Avatar
Just...wow.
I will video the next 'virgin' slice.
post #110 of 185 Old 11-01-2013
Based on what you've found... are you going to tackle the other side 'just in case'.. or to match what you're about to create now?
Faster is offline
Chain Plate Replacement casey1999 Gear & Maintenance 35 05-21-2013 11:53 PM
chain plate reinforcement UseDaGreyMatter MacGregor 1 12-30-2010 11:05 PM
Chain plate help atlanticcruiser Gear & Maintenance 15 12-20-2010 12:46 PM
Chain Plate (Not) davidpm Gear & Maintenance 2 04-14-2009 06:52 AM
Chain Plate Replacement jsutor Gear & Maintenance 1 04-30-2005 03:40 PM
