Embedded Chain plate maint/replacement - Page 15 - SailNet Community
 81Likes
post #141 of 185 Old 01-28-2014
I haven't looked closely enough in person on the 38 to tell how similar the replacement might be, but these are examples of the Irwin 65/68.
Total Chaos is offline
post #142 of 185 Old 01-29-2014
Old enough to know better
Re: Embedded Chain plate maint/replacement
In this case, due to the heavy cap rail and rubbing strake, that would NOT be the easiest or simplest method. It would require either complex bending & shaping of the chains or a lot of work cutting slots in the noted trim.
Bolting them to the inside of the hull in their original positions avoids all that. It does involve a lot of ugly cleanup work of the old glass though.
And it avoids the Ugly bit of having the chain plates bolted to the exterior of the hull. I think it looks like a "cheap and easy fix" when on a boat that did not have it originally. It does make them easy to inspect though.
miatapaul is offline
post #143 of 185 Old 01-29-2014
You are still talking about adding a backing plate then to the outside of the hull right? Unless you use load distrubting plates like the original and reglass them, you would still need polished plates on the outide of the hull if you use any bolts at all. Am I missing somthing?
post #144 of 185 Old 01-29-2014
That's because it is a cheap fix. I don't like external chainplates on any boat, but if I saw them on a boat that wasn't designed with them I would walk away.
The major problem with moving to external chainplates is that they have a larger failure area than on penetrating ones, and are covered in salt water much more commonly.
It really concerns me that people constantly want to mess with the work of a professional NA in such a substantial way without checking with a qualified expert. Swapping around chainplate locations is like moving around the structual walls of your house. Sure it might be ok, but it wouldn't do it without checking with an architect.
Greg
Stumble is offline
post #145 of 185 Old 01-29-2014
The only neg effect moving the chains farther outside is on the ability to close haul, in this case it is only couple inches otherwise the plates are in the same location. The effect on the rig is to actually make it stronger... the base is wider. As to the cosmetics to each his own. The one absolute fact about glassed in plates is that they are 02 starved and water will get in there eventually, 30 years down the road, or 2 and along with that comes crevise corrosion. The only way to inspect these plates is to have gamma radiography done. $1500 just to inspect the plates, hmmm pass.
post #146 of 185 Old 01-29-2014
Not quite true.
1) moving chainplates outboard is only stronger if where the new chainplates are attached is at least as strong as where they were. Since very few boats use completely perpendicular spreaders simply moving them further outboard also changes rig geometry. Keeping them inline with the old rig geometry also likely moves the new chainplates to new attachment points relative to hull deck strongpoints.
2) if you think it's difficult to completely waterproof a 2"x3/4" hole, how much more difficult will it be to waterproof the outer edge of a 3'x2" plate with holes drilled in it.
3) dye testing is much cheaper, x-ray testing is also a possibility both at much lower cost. But I agree with you here generally, by the time you go thru the difficulty of removing them it is generally better to just replace them no matter what you find, since these tests don't address work hardening.
davidpm and christian.hess like this.
Greg
Stumble is offline
post #147 of 185 Old 01-29-2014
christian.hess's Avatar
x2 above
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #148 of 185 Old 01-29-2014
In this particular case.
1. The exterior plates would be just a strong as the oringal, stronger do to compression as the location on the hull does not change, expect as it is not directly on the inside of the hull, but now directly on the oustside.
2. Rig geometry changes are very miniumal as the new attachement is maybe an inch outboard.
3. The glassed in chain plate is oxygen starved, this combined with moisture is what allows crevice corrosion to occur on the plate. It would be quite fine for an external chain plate to leak as far as the intergety of the plate is concerned, but not so for a glassed in plate. If the internal plate leaks and the moister finds its way into a low oxygen environement that's bad news.
4. Industrial inspection companies are all over, but in the US to inspect our chainplates with xray, really it's gamma ray that is used, ranged between $1100.00 and $1700.00 depending on whether they could do it in a full day or half day all of this done onsight at my location. These are US east coast prices and I check with half a dozen companies.
I talked with two separate surveyors and both were quick to say forget the inspection and just replace them. One surveyor said that on any boat with thirty year old plates he has never seen an radiographic inspection come back that wouldnt recommend replacement anyway... ie don't waste your money.
4. External chainplates can be inspected, the internal, even if bolted on the inside can not with out tearing apart a lot of the interior. This may just be the case on my Irwin 65, but on her they are a serious bugger to get to.
All that being said many boats have the chain plates much farther inboard than on the Irwin. Moving the plates outboard on the hull on these guys could be a bad idea for some of the reasons Stumble mentions above.
post #149 of 185 Old 01-29-2014
I would never pay to have plates inspected especially at those prices, considering you can make new ones, beefier or not...or improved for less
keep up the good work op
post #150 of 185 Old 01-29-2014
Senior Moment Member
SloopJonB's Avatar
I've seen gamma shots of chains on a big Irwin and they weren't enough to really tell the state of them. You HAVE to remove them to know if they are O/K and I pretty well guarantee that, after 25 or 30 years buried under glass, at least some of them won't be.
christian.hess likes this.
SloopJonB is online now
Chain Plate Replacement casey1999 Gear & Maintenance 35 05-21-2013 11:53 PM
chain plate reinforcement UseDaGreyMatter MacGregor 1 12-30-2010 11:05 PM
Chain plate help atlanticcruiser Gear & Maintenance 15 12-20-2010 12:46 PM
Chain Plate (Not) davidpm Gear & Maintenance 2 04-14-2009 06:52 AM
Chain Plate Replacement jsutor Gear & Maintenance 1 04-30-2005 03:40 PM
