Embedded Chain plate maint/replacement - Page 2 - SailNet Community
 81Likes
post #11 of 185 Old 10-16-2013
Re: Embedded Chain plate maint/replacement
Originally Posted by overbored View Post
not sure what you worried about where the compression is going. the mast is in compression to the keel. the chainplates are in tension. fiberglass is very strong in tension. get a Fein saw for cutting away the glass. very little dust and the best tool for fiberglass work. worth the money.
FEIN Multimaster Oscillating Multi-Tool Kit-FMM 250 Start Q at The Home Depot
Second the Fein for cutting over a zip-cut/angle grinder.
Faster is online now
post #12 of 185 Old 10-16-2013
Originally Posted by StormBay View Post
...Allied Luders 33, Hans Christian 33, Endurance 35 are just a few that come to mind.
Allied bolted the Luders 33 chain plates to wooden "knees" glassed to the hull and then glassed-over the entire thing.
I would also suggest a multi-tool, not necessarily Fein. I would recommend a Milwaukee which is cordless and comes with two batteries which I was amazed how they last - for a much lesser price (tool and blades). The important piece is the kind of blade, and I would suggest you get 2 or 3 of the half-circle shaped ones with many small teeth - they have worked very well for me to cut thru glass - use a back and forth motion with them. Have a vacuum going at the same time with the nozzle close to the tool and you'll remove the glass cleanly in no time at all.
SVTatia is offline
post #13 of 185 Old 10-16-2013
Jnoiur Mebemr
StormBay's Avatar
Originally Posted by davidpm View Post
I guess I find it hard to believe that a bandage of glass over the chain-plate on the hull is all their is to it.
Is it possible they are relying in part on 5200?
Does polyester resin stick that well to SS?
Did they do some tricks like put some holes in the stainless so the resin would form keys?
The chain plates in this one look like they have bars or rods welded to them, to form the upside down T shape that you see, which is than glassed into the hull. If the plates don't break they would have to rip out all of that glass before they pulled out the T shape bars and therefor don't have to rely on the bond between the fiberglass and the stainless. As SVTatia pointed out the Luders 33 use a different method of doing essentially the same thing (i.e. not relying on the bond between fiberglass and metal but rather fiberglass to fiberglass. Make sense?
davidpm likes this.
Yu & Frank
StormBay is offline
The Following User Says Thank You to StormBay For This Useful Post:
davidpm (10-16-2013)
post #14 of 185 Old 10-16-2013
Old enough to know better
Yes the cheap tools work fine, but the cheap blades don't last at all. A couple of uses in soft wood and the "Workmate" (Loews house brand) brand blade was shot. Though the $35 Workmate brand tool works quite well. I have borrowed a Fein, and it seemed to operate a bit smoother, but did not work any better on my projects. And with all the fiberglass dust, that may just do in the tool anyway. The Harbor Freight multi tools seem to have it's fans as well.
miatapaul is offline
post #15 of 185 Old 10-16-2013
mitiempo's Avatar
It is obviously OK as it has lasted a long time on a lot of different boats. I'm just trying to understand the loads.
The mast is pushing down that makes sense.
The chain-plates are pulling up.
Some portion of the load however is attempting to make the boat narrower.
I see a lot of boats that have the chain plates connected to a bulkhead.
The bulkhead is tabbed into the hull distributing the load.
The bulkhead often has a small beam that goes across the whole boat again distributing the load.
In this case the load attempting to make the boat narrower has to be taken by the deck.
I'm not saying it is a problem unless of course you had a soft deck.
What I'm saying is that a SS bar bolted to a bulkhead makes sense to me. It is obviously strong.
This kind of construction has stood the test of time so must be pretty good, I'm just trying to understand it.
It is a very strong way to attach chainplates if done properly. With a well built hull and deck there are no issues. It is not a bandaid of glass holding them in - the force is straight up pretty much for the uppers and inward slightly for the lowers. The chainplate's force is basically upwards and the overlap of the hull and deck (hopefully not just screwed together) places a good thickness of glass stopping upward movement. The Spencer 35 uses basically the same method except it is a bar that runs fore and aft and not as far down the hull and it has stood the test of time as well as long voyages by Hal Roth, Paul Lim and others.
But with modern knowledge of crevice corrosion it is a lousy way to attach the plates leaving any corrosion hidden from view. With chainplates being hard to seal over time moisture will eventually get in and corrosion will follow.
StormBay likes this.
Brian
mitiempo is online now
post #16 of 185 Old 10-16-2013
davidpm's Avatar
So the next question is how to put it back together again so they can be inspected easily and/or replaced?
Bolting right through the hull is the obvious solution.
External is another obvious solution.
I doubt if most owners would be willing to change the look of the boat that much.
It really looks pretty and is out of the way coming out of the cap rail like it does.
Of course the argument could be made that they lasted over 30 years so put back together with epoxy instead of polyester and call it good for another 30 years.
If a better mounting is impossible maybe this is the right place for titanium regardless the cost.
davidpm is offline
post #17 of 185 Old 10-16-2013
Senior Moment Member
SloopJonB's Avatar
Actually it hasn't. It stands the test of about 25 or so years and then presents a HUGE nasty problem to the owner at that time - keep following the thread to see how nasty. The worst part of it is that it precludes inspecting the chains for crevice corrosion.
It is a quick & cheap way to install chains, no other reason for it.
SloopJonB is online now
post #18 of 185 Old 10-16-2013
mitiempo's Avatar
Simplest solution is on the outside of the hull. Without a bulkhead in each plate's location there are no other options I can see except the original method. That was probably the reason it was done this way to start with - without knees which would have been in the way of interior cabinetry or bulkheads at the right place it allows placement anywhere the builder wanted.
Brian
post #19 of 185 Old 10-16-2013
mitiempo's Avatar
Wonder how bronze would survive installed this way for a few decades. Problem is that water will get in eventually.
davidpm likes this.
Brian
post #20 of 185 Old 10-16-2013
davidpm's Avatar
Once you cut out the chain plates I would be interested in how thick that bandage of glass is covering them?
davidpm is offline
Chain Plate Replacement casey1999 Gear & Maintenance 35 05-21-2013 11:53 PM
chain plate reinforcement UseDaGreyMatter MacGregor 1 12-30-2010 11:05 PM
Chain plate help atlanticcruiser Gear & Maintenance 15 12-20-2010 12:46 PM
Chain Plate (Not) davidpm Gear & Maintenance 2 04-14-2009 06:52 AM
Chain Plate Replacement jsutor Gear & Maintenance 1 04-30-2005 03:40 PM
