Unversal M12 Prop Mirage 275 - SailNet Community
post #1 of 3 Old 10-16-2013 Thread Starter
I have a Mirage 275 with a Universal M12. I can achieve max RPM of 3600 which gives me only 4.5 knots. I thinking the prop is not pitched correctly. No smoke @ 3600. I have read that the recommended prop is 13x8 or 12x9. I have not pulled my prop yet to confirm the size.
Any recommendation/experience for proper prop size?
rnuzzolo is offline
post #2 of 3 Old 10-16-2013
Re: Unversal M12 Prop Mirage 275
It does sound like you're 'under propped', however the lack of speed could be from other causes - growth/other drag source, fouled prop.. there are prop sizing sites on line...
Try running some numbers:
Vicprop - Prop calculator for Displacement and semi-displacement hulls
Faster is online now
post #3 of 3 Old 10-16-2013 Thread Starter
Thank you for the response, the bottom is clean, no additional drag that I can find, previous owner had the same issue.
rnuzzolo is offline
1 inch prop on 25mm prop shaft? lawsonmitchell Gear & Maintenance 12 07-12-2014 06:50 PM
Cleaning Prop. & Replace w/ Folder or Feathering Prop. HighFly_27 General Discussion (sailing related) 17 09-02-2013 09:34 PM
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
New Prop & Shaft - install prop questions preservedkillick Gear & Maintenance 2 05-22-2010 08:46 AM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
